Broken antenna in jack on samsung lcd tv - Televison & Video
  • the_cute_one May 04, 2009
    i have a samsung 50' plasma and the ant jack came completely off. I dont know what to do to fix it. I am kind of low on cash at the moment so maybe a least expensive way to fix? do it yourself suggestions?
  • 12,061 Answers
Ok pretty easy fix... it has most probably broken away from the PC board, and sometimes the "Old" one can be simply resoldered back into position else... get a replacement Belling-Lee Socket from say.. Radio Shack etc, and simply resolder it back, from where it has become detached from.. it will be obvious when examined, there are only TWO connections, Earth and Centre. Carefully remove the Case, find the spot, resolder/reconnect it back on.. ya good to go.
DO NOT work on it while plugged in! GL.
Posted on Jul 29, 2008
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Antenna input on back of tv broken off
if your converter box has rca output toy can hook it up that away. Or you can look on ebay for a new main board. very easy to replace. be sure at all time to unplug tv while back cover is removed.........hope this helps
Dec 01, 2013 | Sharp Televison & Video
Do i need a antienna for regular tv. if i do where does it go in the back of tv. help
Yes of course you do. It goes on the RF coaxial jack (the same one that cable TV would connect tto) labeled antenna. Don't let anyone sell you a special expensive "digital antenna" because digital TV uses the same frequencies that UHF has always used and thereby requires the same antenna, or at least the smaller portion of the older antennae.
Aug 17, 2011 | Vizio L32 32 in. LCD HDTV
No signal on samsung 40"lcd tv
IF it is an ATSC tuner ,newer type ,( digital tuner) it needs better antenna, most importantly Check the cable from Antenna to the connector. using multimeter , put on resistance ,any, anc check both ends of the cable, when there is no change on the multimeter consider the wire is broke somewhere. Make sure the antenna is pointing towards the tv station. also check www.antennaweb.org i think to see the DTV channels in your area. GL
Apr 08, 2010 | Televison & Video
The f-connector of my sharp aquos 46 tv is broken, how to fix it
This is not too hard of a fix, you must unsolder the Old one and resolder the new, you can get the Female Jack, from say Radio Shack, or any good TV, TV antenna store.Remove the back of set with it unplugged and locate socket, unsolder and then replace with new one and solder back on.
Mar 06, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need adator for DTV converter box.
The converter box needs an antenna, but not the one built into the TV. In fact, you should get an antenna designed for the new DTV broadcasts to get the best reception. There are a number of styles and they start at under $10.
To connect the converter box to the TV, you have a couple of options. You can use the channel 3 or 4 output from the box and connect the cable to the TV external antenna jack with the appropriate adapter. Or, since this TV also works as a monitor, you could use the converter box video and audio outputs instead. If the TV has a single A/V input jack instead of separate audio and video jacks (the usual case), Radio Shack and other vendors sell the adapter cable you'll need. One might have been supplied with the TV.
Feb 10, 2009 | Coby Televison & Video
Need to repair antenna jack
The antenna jack repair will depend on the type of parts required and the accessibility to the jack. Usually the jack is in integral part of the tuner module.
In any case this will take experience in TV servicing and will more than likely ordering the replacement part(s) from the manufacture rep, or finding a generic part(s) replacement.
The area of the antenna jack can be fairly critical since it is dealing with high frequency RF frequencies. It may be easy to de-tune some of the circuits when working in this area of the tuner. In some cases the complete tuner module may have to be replaced. I would suggest taking the set to a TV service center to have the job done properly.
Jerry G.
Jan 02, 2009 | Televison & Video
SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Dec 30, 2007 | Televison & Video
Televison & Video Logo
273 people viewed this question
Top Televison & Video Experts
