Question about Goodman CLQ36AR49 Air Conditioner
Condensor fan motor
I replaced my condensor fan motor. the new one has four wires and the old one had only three. what do i do and the color code is different
  • sunshine 111 Jul 30, 2008
    i have a older goodman airhandler and the blower motor went i pulled the wires from the sequencer and got a 4 wire motor how do i wire it please help
You have a reversible motor or a two speed motor check the old motor for speed and rotation
Posted on Jul 29, 2008
Wiring problems
Looking at this from a purely wire color stand point, you have a 220v motor and a 110v motor. What are the model numbers on the unit, and each motor?
Dec 18, 2017 | Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
Replaced a ge condensor fan 3 wire with new dayton the wires are different...old fan has a wire connectort mouted to it orange,black yellow, the new one 2brown 1 with white stripe, purple, black, i have...
the new ge fan requires its own capacitor, the brown and the brown/white go direct to new fan capacitor. black to relay (leg one of power) purple to relay (leg two of power. the compressor will have a wire to the relay and the other to the herm terminal. you now will have nothing to the original capacitor fan terminal.
The new motor will have the diagram showing this. you need the capacitor that goes with the new motor. the grainger guy should have sold that to you with the motor.
Apr 11, 2013 | Heating & Cooling
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
Fan motor on condensor not starting. I have located the capacitor but unable to recognise any writing. it is a12000btu split unit.
There are two type capacitor. One for running capacitor for compressor and one for condenser fan motor by each separate capacitor. Some times two in one capacitor being used. Just check in your condenser unit, in your 2 in one capacitor, there are three parts and one has four pins and other two has each two pins where you can clip the wire.Remove existing wires and replace same with new capacitor.
Now, in this capacitor near each each part mention as "C" "H" " F". Cmeans compressor common and H means for compressor starting and F means fan starting. Be careful don't interchange any wire.
And also while replace capacitor don't add or reduce the mfd. Ex.. your existing capacitoris 35+3 mfd means 35mfd for compressor function and 3 mfd for fan motor function. Hope helpful.
Jan 09, 2011 | Heating & Cooling
I REPLACE CONDENSOR FAN ON A LENNOX BUT THE FAN IS OVER HEATTING AND STOPS& COOLS DOWN AND RUNS
Did you replace the fan blade or the fan motor? If you replaced the fan blade, is it exactly the same blade as the old one? If it has more blades, or wider blades, or if the blades are at a different pitch than the original, it is capable of moving a greater amount of air, but the old fan motor is not big enough in Horsepower to do the extra work. Thus, you should change the blade again to one that is exactly the same as the old one. If it is a window unit, you could try running the fan on a lower speed and it might work.If you replaced the fan motor, you must check to make sure that the new motor is exactly the same as the old one. You also could have it wired wrong, so you must check that also.
Jul 05, 2010 | Heating & Cooling
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Condensor fan runs after compressor shuts off
If new motor is 4 wire verses 3 wire use seperate capacitor between brown wires and don't use terminal on 3 pole cap. If this motor has a white strip on one brown wire you can wire it the old way using only 1 brown wire and tape off the other. Can't remeber this morning which brow wire to use . I need to leave. Goole replacemotor with 2 brown wires for more info or call where you bought it. Sorry got to run.
Jul 01, 2009 | Weather King 12AJA4801AH Air Conditioner
AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
118 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
