Question about Dryers
Kenmore electric dryer model 110.60942990 The dryer cuts off intermitingly and I need to press the start button to start it again. Then it could run for 20 minutes or more with no problem or it could cut off right away again. I then press the start button again to start. It could run for 5 minutes then it cuts off again. What causes this? I have check the air duct and it is all clear.
    Genius:
  • 1,028 Answers
I think model may have what is known as a even heat control possible it may be bad or motor relay just to right of control motor relay is the one with blue wires switch the heat relay the one with big red wires with it to verify to acess both remove screws under end cap..they just pull off.. and lift console up and back
Posted on Jul 29, 2008
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
I press the start button on my whirlpool duet dryer and it beeps, but doesn't start
This is a common issue caused by a blown thermal fuse located on the blower housing and wired in series with the motor. Power to the motor is then cut and therefore cannot run. No dryer function works when the motor cannot run. Click on the link below for the complete details of the troubleshooting and repair procedure.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Aug 13, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer won't run except when start button is held
you need a new start button and switch
Jan 12, 2009 | Kenmore Dryers
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
