Question about Garmin GPS
Lost owner's manual. Etrex software v. 2.14. Can't figure out how to adjust contrast once I'm on the contrast screen.
Needed to push the Enter button twice when in the contrast screen. All good now.
Posted on Jul 29, 2008
Garmin etrex 12 channel gps, screen very dim contrast with new batteries
For the Etrex Legend you can click the page (top right hand) button till you get the main menu, select setup then display. Point the click stick down until the bar on the left is highlighted. You can then move the bar up and down until you get the contrast you want. You could first try clicking the square near the top right and selecting restore defaults, but if the default contrast is not to your liking then you can change it using the bar.
It is probably similar on related models such as the Venture or Vista, if in doubt check your manual.
Dec 30, 2010 | Garmin eTrex Legend GPS Receiver
How to update softwrae
The simplest thing to do is as follows: Go to the following website-
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Follow the instructions from there which state:
WebUpdater is a free application that lets you update your unit software from home. Download it once at the link below, and you can check for and install software updates without using your Internet web browser. Simply run WebUpdater from your computer, and it will do all of the work for you.
Step 1: Download and Install WebUpdater Click the link above to download WebUpdater. Next follow the screen prompts to install the application on your pc. If you have already installed WebUpdater on your computer, skip to step 2.
WebUpdater updates most Garmin products, excluding Palm and Pocket PC devices, fixed-mount marine units, chartplotters, fishfinders and certain discontinued units we no longer support. It does not perform Beta updates. WebUpdater only updates unit software. See our All Updates & Downloads web page for related utilities, drivers, add-ons and the unit software for the excluded units mentioned above.
Step 2: Connect GPS to PC and Run WebUpdater After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater".
Hope this helps.
-Martin
Nov 06, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Sep 22, 2008 | Garmin eTrex GPS Receiver
Bab
Maybe you've adjusted the contrast too far?
Sep 22, 2008 | Garmin eTrex Legend GPS Receiver
Display on etrex Legend is dim
Have you tried Main Manu / Setup / Display and then adjusting the contrast?
Jul 07, 2008 | Garmin eTrex Legend GPS Receiver
A dark screen might be the result of a poorly adjusted display contrast. This can be altered by accessing the Setup menu and selecting Display.
Feb 01, 2008 | Garmin eTrex Legend GPS Receiver
Faint screen image
when you first power on using lower right (power) button, wait 6 seconds for the intro screen to finish. The upper left (up) button increases screen contrast. Hold this one down for a few seconds and the screen should darken. The middle left (down) button decreases contrast.
If this doesn't work, try turning off by holding the power button.
Hold down upper left AND upper right while turning unit on. This initiates diagnostic mode and contrast is darker by default. Bottom of screen is a button test area which darkens a symbol for each successful button press. Use it to diagnose a button problem. Turn off power and on again to leave diagnostic mode.
I wish you success playing with the Etrex.
Dec 07, 2007 | Garmin eTrex GPS Receiver
Need help with Mitsubishi 15
Try pushing the contrast button, and then some of the other buttons once the contrast menu is up. To control those menus you use the buttons on the front of the monitor, not the keyboard and mouse.
Nov 24, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Adjusting contrast on phone
to adjust the contrast, you have to hit the store button, then the arrow keys, which are the two little keys next to the caller id screen. you will then scroll thru the menu. it will eventually come to the contrast. then you use the arrow keys to move it to a darker shade. and hit store again, to store it.
Feb 03, 2007 | Sakar HT-848CL Corded Phone
GPS Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
