Question about HP Office Equipment & Supplies
I have an HP Photosmart C7200 All In One Series. On my previous HP printer, I was able to copy documents and shrink the images. Is this possible on my new Photosmart C7200?
  • 2,427 Answers
Yes it is ,, Once you install the drivers propperly then all the features will be in the toolbar. you can axcessthis tool bar by pressing the copy button on the printer, then you can reduce the image size. Another method is by using the scanner tool bar, aviable in the all programs menu(START / ALL PROGRAMS) once you start the tool bar, simply click copy and folloy the onscreen instructions then set it according to your desire.
Posted on Jul 29, 2008
How to clear a fake paper jam on an HP 7250 printer
To help you troubleshoot the error 'Paper Jam' issue, please find the link given below and follow the step-by-step instructions mentioned on it:
http://support.hp.com/ca-en/product/HP-Photosmart-C7200-All-in-One-Printer-series/3204782/model/3382182/document/c01079884/
If issue persists, it is recommended to contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/ww-contact-us.html
GuruAid.com
May 11, 2016 | HP Photosmart C7250 All-In-One Thermal...
Center images
>> Check the paper is correctly inserted in the printer tray
>> Set guides exactly to paper size (Ex: A4 Paper Size)
>> Copy paste the image into a word document
>> Select the document press Ctrl+E in Microsoft Word
>> Try to Print.
Mar 23, 2014 | HP Photosmart C3100 series
Hp photosmart c310 phot images don't center properly on page
>> Try to Print.
I need to know the settings on the hp photosmart c7200 printer I should be set for me to get the absolute clearest scans of docs and also my drivers license
Hi. Here are the specs of your printer or simply follow this link to know more.. http://www.shopping.hp.com/shopping/data_sheet/cc567a.html
Print specifications -Up to 1200 x 1200 rendered dpi black when printing from a computer -Up to 4800 x 1200 optimized dpi color when printing from a computer and 1200-input dpi -Print speeds vary according to the complexity of the document -Panorama-size printing -Method: drop-on-demand thermal inkjet -Language: PCL3 GUI -Duty cycle: Up to 3000 printed pages per month
Copy specifications -Copy resolution up to 4800 x 4800 -Digital image processing -Up to 99 copies from original (varies by model) -Zoom to 400%, fit to page (varies by model) -Copy speeds vary according to the complexity of the document.
Scan specifications -Image editor included -Integrated OCR software automatically converts scanned text to editable text (if installed) -Twain-compliant interface -Resolution: up to 4800 x 9600 dpi optical (varies by model); 19200 dpi enhanced (software) -Color: 48-bit color, 8-bit grayscale (256 levels of gray) -Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
May 06, 2011 | Office Equipment & Supplies
I have a HP Photosmart All-in-One series C7200. I keep getting an error message saying "Image on Fax Teport is set to Off". Error 388. The proble occurs when we try & send long distance. What should I...
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
to check the error codes and there solution
click on the following link Hope you its satisfactory
ERROR CODES C7200 Series
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3382185#Error386
Jan 03, 2010 | HP Office Equipment & Supplies
HP Photosmart C7200 All-in-One Series is always going offline and then won't print-I am using it with my wireless computer. When I ask it to fix it, it now just says it's disconnected and that print job...
I request you to follow the below web links to resolve the issue:
Weblink1:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01886205&cc=us&lc=en&dlc=en&product=3204785
The above web link for windows 7 but you can perform this any of the windows operating system
Weblink 2:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01084690&cc=us&lc=en&dlc=en&product=3204785
Weblink 3:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01548600&cc=us&lc=en&dlc=en&product=3204785
Oct 12, 2009 | HP Photosmart C7180 All-In-One InkJet...
Too many printers listed
Not sure what happen to this but I had the same problem. What you need to do is highlight each one except the first HP Photosmart 4100 series, and delete all the other ones.
So delete the following 6 printers.
Send to One Note 2007
Microsoft XPS Document Writer
HP Photosmart C4100 series (copy 1)
HP --------------------" ------" (copy 2)
HP....................................(copy 3) AND
HP ..................................(copy 4) which is the only one that works!!!!!
Now the one that is left should be the default. Do a test page or print something out to make sure.
This should fix your problem. Please rate.
Feb 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Cannon scanner D1250U2F and Hp photosmart printer 8250
This is a compatibility issue between the Copy function of Toolbox and the specific HP printer driver. The only work-around would be to scan your image and save it, then print it from another application. One other possibility would be to get Toolbox version 2.2.x from the N650U scanner download page. This version will be limited in functionality, but COPY button should function as expected.
Apr 28, 2007 | Canon CanoScan D1250U2 Flatbed Scanner
76 people viewed this question
Seeker5211
Seeker5211
