Question about Dell Inspiron B130 Notebook
Ispiron b130 wont turn on
My computer will not even turn on plug in power supply to wall light comes on plug it into my computer and light goes dim and flashes what could be the problem
  • 58 Answers
Hi!
Im sorry to inform you that the motherboard on your computer needs to be replaced. If the ac adapter light turns on if not plugged into the system and when you do plug it in, it dims or flashes, that's a right out symptom that the motherboard needs to be replaced. Do you still have warranty for that system? if you do, call Dell Tech Support and have them replace it. If the warranty is already expired, please call Dell at 1-800-2884410 for an estimate on how much it would cost you to have the motherboard replaced. Usually would be around $400 - $500 and 5-8 business days. Unfortunately, you have to ship the system back to Dell for that repair.
Hope you find this solution helpful and informative.
Thanks,
Karlox™ :)
Posted on Jul 29, 2008
My hp envy 20 wont turn on
Need some more info:
Does the screen come on?
-What is on the screen?
--What happens when it fails?
Does a light come on the tower?
-Does a light come on in the power supply (where the computer plugs into the wall)?
Do you hear any beeping?
Do you hear any fans going?
Does the power supply fan (Where the computer plugs into the wall) try to start & fail?
-Or does it not try at all?
Apr 28, 2014 | HP Computers & Internet
87virago1100cc wont kick over seems like a relay or switch cause it wont even click
Do any lights come on when the key is turned? Are you you sure there is power from the battery? If yes then what happens when the start button is pressed? Do the lights dim at all? Even without a click noise if the button is supplying power to the solinoid the oil check/dummy lights should dim slightly. If no dimming but the lights are on when the key is turned, start by checking the starter button, if there is no power there trace your way back to the battery with a voltmeter until you find where the power stops.
Mar 23, 2012 | 1999 Yamaha XVS 1100 Dragstar
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Power Problem. Sudden onset of laptop not coming
The most likely answer is the motherboard will need to be replaced. Here are some troubleshooting steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 14, 2010 | Dell Inspiron E1505 Notebook
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Laptop has shut down with no power lights
laptop dose not turn on but lights are on
Feb 23, 2009 | Dell Inspiron B130 Notebook
Dell b130 will not stay on unless it is plugged into the wall
The battery may be bad or the charging mechanism of the battery area. OR you may have some undocked (battery run setting) that is dimming the screen or turning off the monitor when you are running on battery where you think it is off but the screen needs to be lightened or powered on.
I would first take a look at your Power Settings in the control panel and see what they are set to.
Jan 28, 2009 | Dell Inspiron B130 Notebook
Brand new router works sometimes
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Inspiron B130 Notebook Logo
160 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
