Question about Mitsubishi WS-55859 55" Rear Projection Television
The Cost?? Where can I go to Get 1 !! Thanks Randy
THE STORE!!! :)
Posted on Aug 18, 2008
Issues with Charcoal canister, trac off and check engine light
Please contact randy on the original link for the first time you posted this, do not post a new question.
Aug 29, 2016 | 2013 Scion xB
My wash machine leaks from the bottom coming from the middle need help. thanks randy
Hi Randy
If your washer is a top load it is probably leaking from your drain pump which is underneath center of the unit.
Luigi
Feb 23, 2011 | Washing Machines
My GE Profile Dryer (purchased it new about 5 years ago) part number 3850EL007A is not blowing air out the exhaust tube. I checked the air path and it appears clear. However, the air inside the dryer...
Randy,
I would first disconnect the vent tube a feel/see if it blowing out the back of the dryer, it should be but if not then I would take the front panel off:
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look for lint on bottom and inside dryer
Hope this helps Tim
Sep 25, 2010 | Dryers
My 34" SONY Trinitron WEGA won't turn on. It make a sound like it's starting then I hear a click and it's gone. The screen never lights up. Randy Kessinger
Hi Randy, the vision IC is bad, it requires replacement so please take it to a qualified service personnel for replacement assistance. Do not try anything further.
thanks
Apr 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a older model # 30 jiffy ice auger and i can not seem to keep it running consistanly. I was wandering what the carburator adjustments are. The low idle screw and the high idle screw where do I start...
Hello Randy. I can talk you through making adjustments to your Jiffy ice auger engine.
1. Read through the whole list before you start adjusting.
2. Close both jets GENTLY
3. Open the Low speed 1/4 turn
4. Open high speed jet 1 1/4 turn
5. Start engine.
6. Adjust low speed until idling smoothly.
7. Open her up wide open.
8. Adjust High speed until engine transitions smoothly from idle to high speed without bogging.
9. Shut engine off. Let it cool.
10. Once engine is cold. Fire it up and let it idle for 30 secs. Open it up wide open again. Adjust if necassary.
NOTE 1: The trick with the Jiffy's is to tune them during cold (ice fishing) weather.
NOTE 2: Low speed screw,the one on the left.
NOTE 3: High speed on the right.
Good luck ice fishing! Regards, Joe
Dec 31, 2009 | Sport & Outdoor - Others
Radiator has begun to leak. Is this usually a
where is it leaking from find out and get back to me buddy
Oct 10, 2009 | 1985 Yamaha XJ 700 X Maxim
Balance #CN6555 note book
A local PC store should be able to supply at least the power connector that is within the laptop. A lot of laptops only have solder points holding the power connector in place. Over time and putting pressure on the power cord will loosen those points. The power connector itself should cost about 50 bucks. Having it installed depends on labor charges.
G'luck
Oct 23, 2008 | Balance CN6555 Notebook
Mitsubishi WS-55859 55" Rear Projection Television Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
