Question about Dishwashers
Wash cycle works ok, but no water during the rinse cycle, the pump just keeps running all the time as if it was draining water
Water will not drainout. pipes are clean of dirt
Posted on Jul 29, 2008
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Kenmore washing machine not empyting all the way during the rinse cycle? the machine washes fine but not empyting all the water during the rinse cycle?
Does it go into high speed spin? If it does and there is still water than check to see if the filter or hoses are clogged. The hoses the run from your basket to the pump and the drain hose too. A washer is only given so much time to drain all the water. Most of the time the filter or coin trap hose is clogged. If everything is clear u may have a weak pump.
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
Not draining..agitator making a grinding type of
The bad news is with the combination of not draining and the grinding it is undoubtedly the drain pump. The good news is they are not difficult to replace. Let me know if you need any info on replacing it yourself and I'll try to give you the steps needed.
Hope this helped.
Sep 14, 2009 | Washing Machines
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
Top Dishwashers Experts
