Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor RSD30S F1 Error Code
The F1 error message pops up on the display. The cancel button silences alarm for only a few seconds. However, if I start any bake cycle the error clears. Only problem is that the heat won't shut off, even after the cycle terminates.
The Dacor Owner's manual states that the F1 code is a relay failure. Is this the cause of the range heat not shutting off? Can you suggest the proper procedure to fix the problem?
  • 1 more comment
  • Clif 42 Jul 30, 2008
    I need part number(s) and step by step instructions on installation of said part(s) in order to solve the issue.
    Please advise.
    Thanks!
    RSD30
    F1 Error Code
  • 868 Answers
With the amount of problems you have stated ,I do believe you may have the record for the total number of problems on 1 product.If you take the most critical from the group and compare it with the cost of a new oven,you will be saving money replacing the oven. I'll walk you through the whole repair if you would like but after adding up the total It would not be fair to let you invest in a losing fight.
Posted on Jul 30, 2008
    Genius:
  • 1,665 Answers
See item description at link (Relay pcb range 105 c; ers )
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
  • 2,071 Answers
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
Dacor RSD30S F1 Error Code - small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif ElectricDacor RSD30S F1 Error Code - redarrow.gifng
redarrow.gif Gas Cooktop
redarrow.gif Electric Cooktop
redarrow.gifGas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
hope this may help;
Regards,
VOTIT
  • 13,433 Answers
F1 Element relay circuit failure - The relay circuit would need to be replaced.
the part should be available at
just type in RSD30S into the search.
  • 1 more comment
  • Ekse Jul 30, 2008
    Item # 740533 - Price 267.05
    http://www.repairclinic.com/SmartSearch/...
    I would recommend as the price of the part is higher than I expected, possibly get a repair man to assist you with the repairs or do the replaceing.
  • Ekse Jul 30, 2008
    also ask your repair man to confirm that the part fits your model and is the right one to replace.
    He may possibly have a cheaper deal somewhere.e
  • Ekse Jul 30, 2008
    do you see my solution?
Oven keeps asking for probe
connect probe and insert probe
Jul 26, 2015 | Kitchen Ranges
How do i find out what the frigidaire gallery series dryer error messages are
Hello Friend, this is Z. I appreciate your post!
To get the error code your dryer may be experiencing, attempt the following:
Wake your dryer by pressing any button except for CANCEL.
Press and hold the "CANCEL" and "START PAUSE" buttons simultaneously for 6 seconds to show the error recorder code your dryer may have. The error code normally appears in the display as an E followed by two numbers.
If your dryer shoes, E00 it indicates no failure code was detected.
I ask that you please follow up with a comment on the post, at your convenience, to advise if you receive an error and if further troubleshooting is needed.
Thank you!
Jul 17, 2014 | Frigidaire Dryers
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Whirlpool gold accubake system keeps displaying the message "Dr Lo". Every 60 seconds it will beep like 10 times and display the message then display "start?" Normal function dont work either I can push...
The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
Dec 18, 2013 | Kitchen Ranges
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Error code f1 e3
Try this out,
FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
per wiring diagram before performing the following steps:
STEP 1 Power off and wait 5 seconds.
STEP 2 Power on and wait 5 seconds.
STEP 3 Press the following keys:
CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
STEP 4 Press START.
STEP 5 Make sure Timer ID is the same as the oven.
STEP 6 Press CANCEL to exit.
Nov 27, 2012 | Kitchen Ranges
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
F1 error code on Dacor RSD30S. Code comes on for no apparent reason, range not in use. Hitting cancel no longer resets range, I have to pull fuses to stop beeping.
The F1 error code means that a button on the touchpad is stuck and sometimes it could be resolved by clearing the code by pushing the cancel button, having done that and it no longer clears that F1 code the touchpad would need to be replaced to keeping it from beeping nonstop.
The part number for that touchpad is 82063B it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kitchen Ranges
My RSD30S Dacor Range is giving an F1 error code for a while now. What is the expected total cost of repair?
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 26, 2011 | Kitchen Ranges
Dacor Preference RSD30 Gas Kitchen Range Logo
776 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
