There has been some recent discussion on the delay in focusing with digital
cameras.
I was at Wanaka and experienced the same frustration that others reported in
trying to capture moving subjects. My camera is a little Fuji and I guess
it is the first time I have had problems as most prior subjects were static
or slow moving.
After checking the operating instructions for the camera I was surprised to
find that there doesn't seem to be an facility for manual focus. Since most
of the shots were at infinity it would nice to be able to lock the focus
(like on a regular camera) and minimise the delay in taking the shot.
Or is it not that simple?
Incidentally is all the hype about megapixels overdone? My 2 megapixel
camera has produced some very repectable A4 size prints on glossy paper - at
least to my eyes. I wonder if there are other more relevant attributes like
low light sensitvity and colour resolution.
Cheers,
John
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Coop
To reply, remove the nose wheel.....
Rating: 0%, 0 votes
wrote:
I seem to recall a technique of bathing the film in hydrogen to up
it's sensitivity used in astronomy.
Rating: 0%, 0 votes
Careful explanation snipped - ta.
Hmm - shoulda charged you for 'em :-)
I thort you ran into grain size problems if you pushed it too far - and I've
never heard of anything like 51k ASA!
(My only processing experience was with B&W Panasonic X and Tri-X followed
by conventional papers.
Did jag a couple of nice ones, which made it worth it - have now given the
gear to a niece who has jagged some very nice ones :-)
Rating: 0%, 0 votes
(snip rest)
This WAS the point in an earlier thread, but it was subsumed by discussion on
autofocus. And this remains the issue with any "budget" digital cameras i.e.
<$A1K
Rating: 0%, 0 votes
Actually it is PF (FPs are different)
See http://www.dhios.co.uk/archive s/flashbulbs/Bulbs1.htm
which gives data for every imaginable type of flashbulb.
Mmm - well not quite. They list the PF25 but not the PF25B, but do list
both PF5 and PF5B
Perhaps I misremember - maybe there was no 25B, just the 25/97. (The /97
indicated blue)
*Was* a while ago :-)
Rating: 0%, 0 votes
wrote:
That chart has explained a lot, cheers :)
Rating: 0%, 0 votes
wrote:
Actually it is an FP25, and the FP lamps had relatively long duration,
and constant output during the burn so they would provide more or
less even illumination as the Focal Plane shutter moved across the
film plane, which typically took something on the order of 30
milliseconds. The FP synchronization on the camera would close the
contact something on the order of 10 milliseconds before the shutter
began going across the film. That was to allow them to light and reach
full brightness. Total burn time was typically about 40 milliseconds.
Higher voltage doesn't do a thing for them. It is the current that
counts, you need to get them to light, and is ohmic heating, anything
over 3 volts could usually light them in a millisecond or so...
plan B of course is to fire off a few kilojoules in Xenon flash tubes
in a few milliseconds. That provided enough light for arerial
photography at night.
Burn the print off the paper.
Rating: 0%, 0 votes
(It's a depth of field calculator)
Rating: 0%, 0 votes
shutter button (In fact it also allows full manual mode where I focus it
myself)
With prefocus you simply aim it at something about the same distance away as
the item you want to capture. This also works to compensate for someone up
against a bright window or the like. Prefocussing on something with better
lighting adjusts the settings according to THOSE lighting conditions,
meaning you can get a better result for the photo you want to take.
The problem I have with this particular digital is not the delay in focus,
but the delay in CAPTURING the image.
Even manually, or pre-focussed, there is a huge delay from when you finish
pressing the button, to when it decides to capture the image, so you don't
get the shot you wanted.
For example, I had a father holding his toddler daughter. She was eating an
iceblock, and regularly holding it up for him to take a bite - SO CUTE.
But try as I might, the delay was so long, that taking the shot as she held
it out to him, he had already taken a bite, and she'd returned the iceblock
to herself by the time the photo would capture. To get the shot I'd wanted,
I'd have had to predict when she was going to hold it out - but it was
random - and press the button a moment before she began to hold it out for
him. Not being good at forseeing the future, or reading minds, this doesn't
work well.
This REALLY frustrates me. And basically destroys what is otherwise a
fantastic camera. Brilliant if you want fixed images like landscapes etc.
Totally USELESS for those fantastic candid-moment type shots - unless you
"pose" the candid moment - which I ended up doing with that father and
daughter, by getting her to hold the iceblock there, but it just isn't the
same thing sometimes, the facial expressions etc are rarely the same when
posed.
The resolution of 6 megapixel, which is really 3 megapixel but using a
"Super-CCD" to get more dpi than the normal 3 megapixel gets, is way ample
for my needs. It produces fantastic A4, and still exceptional A3 shots. I
just wish they'd do something with the delay in capture.
Rating: 0%, 0 votes
wrote:
Thanks for that link... :) i played with focal lengths...god....
how the hell do ya focus on a subjet 4.5 kms away with the hyperfocal.
Rating: 0%, 0 votes
Would either of you care to comment on the depth of field as a function of
lens focal length vis a vis aperture??
ie - depth of field of a 70 mm lens at f3.5 is greater/less than the depth
of field of a 70 mm lens at f16?
depth of field of a 70 mm lens at f3.5 is greater/less than the depth of
field of a 700 mm lens at f3.5?
(OT - Stealth, I got some $s and am back on m'ship)
(OT - Paul - you firing those PF25Bs at 10KV to get 51,000 ASA or what?)
Rating: 0%, 0 votes
threeweeks@f8
Rating: 0%, 0 votes
Reading your stuff again and observing your burning film again
I have a T90 cannon here with 200 mil lens
you can borrow if we cross paths in the scrub.
talung1 at hotmail dot com
put Paul sacacs in subject line to beat
spam filters also my bullet proof TLB lovely tough old gear
T90 only shot about ten rolls in its whole life
Rating: 0%, 0 votes
three weeks@f8
<GRIN>
Rating: 0%, 0 votes
And for you young kids, PF25B (later called PF5B) are blue flash bulbs of a
particular size (bigger than PF1s) - in this particular case some I had and
sent to Paul S. And if you don't know what a flash bulb is, refer Google
Rating: 0%, 0 votes
P'raps we can rename him O Winston Sarkers :)
Paul Repacholi 1 Crescent Rd.,
+61 (08) 9257-1001 Kalamunda.
West Australia 6076
comp.os.vms,- The Older, Grumpier Slashdot
Raw, Cooked or Well-done, it's all half baked.
EPIC, The Architecture of the future, always has been, always will be.
Rating: 0%, 0 votes
so when long exposures mean more chopping off of desirable bits they
have less depth of field.
saccas where do you get the exotic camera gear you use? ...the CIA?
Stealth Pilot
Rating: 0%, 0 votes
John
Rating: 0%, 0 votes
Feel free to post your question in aus.photo - you'll get (hopefully)
a good range of answers/suggestions from us regulars there...
Cheers,
Richard
Rating: 0%, 0 votes
simple fix or alternative.
Thanks for the info GB - much appreciated.
Must say I am very happy with my camera apart fom the focussing issue. Use
it regularly for work - damn convenient for taking shots of parts that are
difficult to describe to suppliers. Even used it on macro to get details
off printed circuits boards that my eyes have trouble reading.
Cheers,
John
Rating: 0%, 0 votes
the problem you have is depth of field ...or the lack of it.
I last studied this stuff 30 years ago but long focal length lenses
have very shallow depth of field as I recall.
Stealth Pilot
Rating: 0%, 0 votes
last airshow I was at I was using an eos 1000f (gasp)
with a tamron 70-300 (LD572) I tried the trick of
focusing on the horizon then tapeing up the lens
and turning of the auto focus. no problem except I
have found that all auto-focus lenses focus past infinity
when pointed at the horizon. when taking a shot of a plane
200ft away its not in focus. focus on the plane and the
horizon its out. not that long ago I got and EOS630 tried it
at the airport, and put on the vivitar 100-300 same thing.
I grab my AE-1 and put a 200mm lens on infinity, problem gone
no focusing past infintity and everything beyond 40ft is in focus.
So I have been wondering for quite a while why auto lenses go past
infinity, any thoughts?..Do digi SLR's focus past infinity?
TIA.
Remove "DoNotSpamMe" to reply
Post a New problem for Vivitar 100-300 mm Telephoto Lens for
Email this problem
