Question about Kodak EasyShare Z1275 Digital Camera
Shuts off when i try to zoom.....
I brought camera back from beach and bottom lens shield wouldnt close.
I blew air into it and was able to get it to begin working properly.
NOW, when i try to use the Zoom function (IN or OUT), it shuts off a split second after it starts to perform the zoom.
Could there be sand stuck in the zoom mecanhics?>
  • likklesprog Dec 22, 2008
    Had the same problem too since going to the beach, the shutter was jammed as was the zoom, cleaned it out with a paintbrush to remove most of the sand, but seems like there is a lot inside the mechanism that I can't get to. It'll zoom out 100% but on zooming back in makes a nice grinding noise and stops.
    I'll give the vacuum thing a go but does anyone reckon it'll be covered on warranty or will they class it as "misuse/malicious damage", as clearly you're not meant to get sand in it!
I was also having a similiar problem with my z1275 and tried the "vacuum" thing. BINGO! It worked, and I was about to send the camera back to Kodak for servicing. You saved me money.
What did I do?
I turned my vacuum on, stuck my lense into the vacuum tube, zoomed all they way IN and then turned the vacuum off. My camera now works perfectly.
Before using the vacuum, I was only able to zoom about 50% before the camera would turn off. Thanks for your help.
Posted on Aug 20, 2008
    Sergeant:
  • 152 Answers
Unfortunately it does sound like there is sand in it,you maybe able to remove it first I would try a vacuum on low settings.Then if that doesn't work if you are really good with small parts you maybe able to take it apart to remove the sand.It would more then likely be more expensive to get it repaired then to just replace.Hopefully my tips will help.
Posted on Jul 29, 2008
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Cameras
Camera lens will not come out all the way, and the screen says to turn camera on and off again. and absolutely nothing happens.
I brought my cybershot 7.2 to the beach, and stupid me did not have it in a proper camera case, and I am sure that a grain or two of sand got into the zoom lens. I used a sewing needle to no avail to try to probe this out, and in the end all I did was use my fingernail to help pull the zoom lens out, when turning the camera on, this worked perfectly after a few try's and the camera is now functioning as good as new.
The grain(s) of sand were obviously preventing the motor from opening the zoom lens.
Hope this helps.
Steve
Oct 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
My kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
Jun 24, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak C330 [lens error 14]
Hi Jesse, thanks for coming to FixYa.
The problem your having is that sand and/or dirt gets in the lens mechanism of the camera. When the little cog inside gets sand in it, it prevents it from moving. It is what causes 95 percent of all lens errors. The other 5 are when the retaining pins get misaligned and don't go back in the holes. Mis aligned pins happen alot of times when you drop it with the lens extended, so let's go with the easy one first.
Take an air compressor (or borrow a friends) and put the nozzle up to the space in between the lens and and the camera. Blow it out real good. It may take a couple of tries, but it should free it up.
Let me know if that helped, and feel free to rate my answer.
Rob
Mar 04, 2009 | Kodak EasyShare C330 Digital Camera
Lens error
Hey jennbrady24,
What is most likely causing the lens error is that something is obstructing the movement of the lens (i.e. sand). I would first try removing the batteries and the memory card and waiting at least 2 minutes and then reinserting them. If this doesn't work I would then try blowing compressed air into the lens to try and dislodge whatever is causing the lens to stop moving. If this doesn't work I would try placing the camera on a flat surface with the lens pointed upwards, then press and hold the shutter button while you turn the camera on. If none of these options work I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 04, 2008 | Cameras
NIKON L15 LENS ERROR
Lens errors, must be fixed by a camera repair shop. They are usually caused by impact of the lens with an object or sand from a beach. Repair estimates range from $50 to $100. Get a new camera if it is closer to $100. Suggest a internal zoom lens like the Fuji Z10fd.
Mar 19, 2008 | Nikon Coolpix P1 Digital Camera
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Detaching the lens
Perhaps a Vacuum will help if it is sand in the mechanism then has to be sucked out - not blasted further in. But I fear it may now be terminal. Preparing these item is not an economic proposition
Jul 02, 2007 | Kodak EasyShare DX6490 Digital Camera
Coolpix 8800 shuts down
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed. When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage. Good luck
May 19, 2006 | Nikon Coolpix 8800 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
243 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
