I have a Pixma 830. I started printing a single page, single-sided document from the top feeder. The printer started doing a double-sided printing. To save time, I hit "stop reset." Apparently, that was the wrong thing to do. The "alarm" button went on, and I got error message 6A00, which I understand probably means there is a paper jam. That's understandable because the printed paper did not come out, but I don't see where it is so I cannot clear the jam. Any ideas where I should be looking?
Kyocera printers are well-known for their efficiency to produce brilliant color prints. The printer can deliver high-resolution output with crisp black and white text and graphics. The CS Kyocera CS3011ikx printer can print multiple copies that can be folded into a single booklet. Printing a booklet can minimize cost. Read through the instructions given below to understand how to print a 11X17 booklet on CS Kyocera CS3011ikx printer.
1 Press the Copy menu on the control panel to initiate the process. Select the Layout Edit tab.
2 Click the Booklet option.
3 The printer supports single-sided and double-sided printing. Choose either of them according to the printing requirement.
4 Change Default settings and mention the size of the media.
5 Place the original document or text in the document feeder.
6 Press the Start button.
7 Select the appropriate print size. Modify the size as 11X17 to meet the booklet requirement.
8 Change the page size.
9 Open the PDF document.
10 Select the options File> Print. Choose your printer from the list displayed on the screen.
11 Cut and staple the edges of your booklet. Trim the ends of the pages if it is necessary. Call our Toll-Free 1-866-293-9220
This model printer does not have a duplex unit and cannot print double sided documents automatically. DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER If your printer does not have a duplex unit then the printercannot print double sided pages automatically. You can print double sided pages but you have to do it one page at a time. First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2. Then print page 3 on one side then page 4 on the other side and repeat for therest of the document. I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
The use of the top paper feeder is the capability to make single or multiple photocopies and for single scanning or multiple scanning. All you have to do is to put single or multiple document in the top feeder and press the COPY BUTTON (third button-right side). Then it will feeds automatically.
The same with scanning, press the SCAN BUTTON (first button-left side) and it will scan single or multiple document.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
