Question about IBM ThinkPad T40 2373 Notebook
T40 2373 ibm fan error
I had fan error, replaced the fan with a know goon fan, the fan still does not work. what else can be wrong with it?
    Genius:
  • 2,028 Answers
One of three things; 1- when the fan codes on some IBM's, the code locks in the bios, there is a download the has to be ran in order to clear the code and the machine to run properly. Check IBM's support site to see if this is the case for your machine 2- If the machine overheated in the process of the fan going out, then the processor may have been damaged, causing the problem and 3- if there was a malfunction with the motherboard which initially caused the fan to stop working, a new fan won't work either. Test the old fan by hooking power up to it, it is power direct and has two leads positive and negative, when power is applied it will run or not. If it does run then the problem is with the motherboard. Try these and get back to me.
Posted on Jul 29, 2008
About 50% of the chance when I turn on the computer, I got "fan error" on left up corner of screen. Another 50%, it is normal. Can you tell me how to fix it?
Thanks!
Posted on Nov 16, 2008
Cpu fan error
Well it usally means the fan is bad it may work and keep your CPU cool but it can still send the code just replace the fan
Oct 25, 2013 | IBM xSeries Computers & Internet
Thinkpad X41 starting two short beeps, fan error and shuts of
The IBM POST code states that after the 2 beeps the screen displays the error.
In the case you have a faulty fan and it needs to be replaced.
Sep 19, 2012 | IBM ThinkPad X41 Notebook
Fans wont work ibm x3400
Remove fan that is having Amber from Fan bay . Clean fan slot as well as bay slot . Then Refix it . It will work .
Feb 20, 2012 | IBM x3400 Server
I have IBM 300pl. And it has strange fan problem.
A fan that no longer works will cause a heat problem. While it may not cause a complete failure, it can cause some strange things to start happening. Your best best is to shut the PC down and remove the cover. Restart the PC an determine which fan(s) has stopped working.
At this point, you can either 1) contact IBM for a replacement fan or 2) remove the fan yourself and google the name and model number of the fan to find a direct replacement and either order online or 3) visit a local PC repair shop to buy a replacement fan that matches the defective one.
Buying direct from IBM will probably cost the most, but will be the exact type needed for your PC. Buying locally will probably be cheaper and faster, but may not be an exact replacement unless it is the same model, etc.
When calling IBM you'll need the computer model, serial number and any other identifying numbers on it for them to help you out.
Sep 18, 2009 | IBM PC 300PL PC Desktop
Fan error on ibm thinkpad
take it to the technician remove the fan clean the dust then put it again if its not working then change the fan
Sep 04, 2009 | IBM ThinkPad G41 Notebook
Fan error in R52 IBM thinkpad
You get a fan error? That means the heatsink fan isn't working you will probably have to call lenovol (They replaced ibm).
Aug 22, 2009 | IBM ThinkPad R52 Notebook
Fan Error
You may have a faulty fan, check to fan, it should spin freely, if not the fan needs to be replaced. The fan and heatsink assenble may also be clogged with dust, remove the dust and vacuum to clean.
Jun 07, 2009 | IBM ThinkPad R51 Notebook
Fan error
fan error means that one of the fans inside the computer has failed and is no longer working causing the system to overheat. to solve this you must replace the fan that isn't working. you should try going to your local computer hardware store and ask them to fix the problem.
Feb 26, 2009 | IBM (04P3161) Cooling Fan
Re: t40 ibm fan error
Are you talking about the original fan being good or the replacement? If it's the original, then your problem may lie with the processor or mainboard. Try the download first, you will need to access another computer to make a bootable disc for the download to clear it. I believe with IBM you can make a bootable floppy or CD. If you have a floppy for your machine, some don't. Once you've made the disc or floppy, you will need to enter the boot menu, and boot from the proper drive. I'm out for the night, but I'll be back in the morning. Let me know.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
Laptop Fan?
Before getting the fan replaced you may want to try to blow the fan with an air compressed duster. Worked for me. You do not need to take the laptop apart completely. There are 4 screws that holds the keyboard in place, unscrew the 4 and you should be able to pop the keyboard out. Once the keyboard is off you should be able to clean the fan.
May 13, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
1,154 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
