Question about RCA R52WM24 52" HDTV Projection Television
About rca model r52wm24
Hi again.
am not really sure how to respond to the same post caz i am kinda new to this. the problem was that i was looking for a board (thats where you connect all the input and output cables) for rca tv r52wm24. you then replied and ask me if the chasis no. was the same as ITC222. i then replied to same yes it was the same. thanks for helping.
philip
  • philip_monro Jul 31, 2008
    just writing to say thank you very much
  • RCA Master
  • 8,617 Answers
Yes I know where you can get the signal board for your model. Go to the following link and leave them a email with your model and chassis number and let them know you need a signal board. They will respond back quickly. they have about any bopard you need for RCA they dont list them all, but inquire, and I am almost positive that they have one.Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 29, 2008
  • Sonny Berry
    Sonny Berry Jul 31, 2008
    youre welcome let me know if you need more assistance.
I NEED TO KNOW WHICH KIND/ITEM# OF PROJECTOR LAMP FOR A RCA R52WM24
look for the model number on back of your tv then go on google and type brand and model and part you are looking for e.x Lamp
Feb 08, 2010 | RCA R52WM24 52" HDTV Projection Television
Projection TV parts source?
has plenty of screen components for the RCA and GE models HDTVs
Jan 25, 2009 | RCA R52WM24 52" HDTV Projection Television
Did you get an aswser on the IC's?
THe rca itc222 chasis has No convergence ics it uses a series of transistors to do the same. YOU replaced the Fl231 fuse and it blew. Did you resolder flyback connections. this is why the fuses blow. check out the article under the tips and tricks section written by me willtab ... see if this helps if not let me know .. i see alot of these at the shop ( i got one right now in front of me with the FL231 probelem LOL) if can let me know i give you help
Sep 15, 2008 | RCA R52WM24 52" HDTV Projection Television
R52WM24
I will need you to look on the rear tag and let me know the chassis number as that model was produced with two different chassis numbers ITC222 and the ATC221 chassis was used, But the chassis number will be on the tag on the rear panel. Please reply to this same post and I will help you locate the power supply board.
Aug 13, 2008 | RCA R52WM24 52" HDTV Projection Television
I have no clue what your trouble is unless you respond to the origional post each time. can you let me know what your symptoms and or trouble was and I will try and assist you.
Jul 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Looking for R52WM24 part
That should be the ITC222 chassis, can you look on the rear of the set and let me know which chassis it has listed on the tag, I should be able to help you out. please respond to this same post.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
No picture when the power button is green
Can you look on the rear panel and post the Chassis number to your set as that model has used 3 different chassis designs. They have a ITC222, ICC222 or a ATC series. If you can respond to this same post with the chassis number I will be able to assist you with the problem
Jul 11, 2008 | RCA R52WM24 52" HDTV Projection Television
REPLACE SCREEN
There are 4 variants of your model listed. Can you please post the complete model number? There should be letters and numbers following the R52WM24. The front protective screen does not appear to be a separately available part. The screen assembly runs about $170. Post the exact model and I'll get you the order number and costs.
Dan
Jun 09, 2008 | RCA R52WM24 52" HDTV Projection Television
I need the code to program a magnavox remote to a RCA tv
A magnavox remote should program like the phillips universal. I will post the link. If this doesnt help post the model number of the magnavox remote that you are trying to program. the model number is usually in the battery compartment.
http://www.universal-remote.net/philipsmagnavox.html
Feb 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Double vision and no convergence
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
Jan 01, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
