SOURCE: Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
SOURCE: Our dishwasher's lock indicator won't turn off,
Try holding the button down for longer say 5 seconds. When you push the button and hold it the little green light should blink. I would disconnect the power for longer..try 20 minutes. If that does not work then remove the inner panel and disconnect the control panel connector from the control box then plug it back in...see if that clears the locked control. If it continues to have a problem then you may need to replace the control panel.
SOURCE: How to reset dishwasher maytag MDB9601AWB?
let the breaker sit off for an hour, if that does not work it needs help
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
SOURCE: Maytag, MDB9100AWW, Serial # 13125545WZ.
Hello, welcome to FixYa.
I'll start by saying the "2" in the display when you press cancel is normal. If you allow it to complete it should initiate the drain before you press cancel the second time.
Initially It sound's like a fill valve or stuck float assembly, though there are many possible scenarios that can include a heating element or a control board, so I'll need to clarify the unit will indeed complete the cancel if you do not push it the second time and if it does complete the cancel will it then in turn start a new cycle ?
Let me know what you find or if you can add any further details and I'll try to help moving forward any way I can. Good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
