Question about Oritron NPD3117 DVD Player
Oritron dvd 3119 player
How can I reset my Oritron 3119 player to get it back into NTSC and not PAL mode?
Thanks
  • Anonymous Sep 10, 2008
    I cannot get the 3119 Back to set the PAl/NTC the screen is rolling and I can't read the menu. How do you reset it ?
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Posted on Sep 22, 2008
I would make sure to add step 2.1 which is to select the menu button. I tried these steps but without selecting the menu button first, I could not reset. Good luck
Posted on Jan 01, 2009
Colors are off
Hi!
maybe your PAL NTSC SYSTEM mode is in accidentally switch to PAL or NTSC try to re switch the PAL NTSC SYSTEM mode.
Nov 02, 2007 | Mitsubishi WD-52725 52". Rear Projection...
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
No Auto mode (NTSC/PAL prsent separately on LG DV388
Some players don't come with Auto mode but you can as well check the user manual and see if there is an auto display mode feature
Jan 11, 2018 | LG DVD 5183 DVD Player
Password to unlock Oritron dvd player
i need codes for my universal remote oritron dvd player #3119
Apr 21, 2008 | Oritron DVD4119
after unsuccessfully trying to naviagate the menu , i unplugged the dvd player for 10 or 15 min. then plugged it in again and changed the output i had it plugged into,,from video 1 to video 2 and i got my picture back it seems fine now
Apr 03, 2008 | Oritron NPD3117 DVD Player
PAL mode ?
PAL/NTSC is automatic. if you insert a PAL DVD output is PAL ( most probably PAL-B. Some other brands allow manual PAL/NTSC switching, but at this machine this is automaticaly done. Please verify your TV set allows PAL programs
Oct 27, 2007 | Sony DVP-NS50P DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
Oct 04, 2017 | Oritron Televison & Video
Oritron NPD3117 DVD Player Logo
914 people viewed this question
Top Oritron Televison & Video Experts
jairo sanchez
 Grubhead
Grubhead
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
