Question about Whirlpool Washing Machines
My Whirlpool Washer model LLR6144BW0, the agitator stopped working and when it goes to the spin cycle there is a loud clicking noise and it didn't drain properly. Is this something I can repair?
  • 878 Answers
SOURCE: Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver
Posted on Apr 27, 2007
  • 10 Answers
SOURCE: Washer won't spin or drain.
This site may help:
Posted on Oct 28, 2007
SOURCE: Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Posted on Nov 24, 2007
  • 83 Answers
SOURCE: Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Posted on Nov 30, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
Nov 22, 2013 | Whirlpool Washing Machines
Have a Kenmore series 90 washer. During spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. In actuality, the agitator will still spin somewhat due to the oil moving the shaft.
If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators (about 1/16"). We had the same problem. Ours was a major gear noise but a clicking could also be a symptom.
A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Apr 09, 2010 | Kenmore 22422 Top Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
My washer is making a loud, clicking noise
One of them underwire garments could be stuck in the pump and eating a hole into it.You should take the cover off and take a look at it in motion without the case.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
Agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
Dec 25, 2008 | Whirlpool Washing Machines
Washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers!  I have same problem.  So far, best I have found is at
diagnosis by someone who knows.  What William Burk says there makes sense.  However, to get to the drive block there's quite a bit of disassembly required.  I am stopped because I cannot get the spanner nut off.  Hope this gives you some help toward finding a more comprehensive answer
Jul 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer spin cycle noise
Likely you need either an agitator repair kit or need to replace the direct drive clutch assembly. The drive coupler is a fail-safe device and generally fails for a reason. In order to repair the agitator, you will need to acquire an agitator hub nut wrench.
Feb 18, 2008 | Washing Machines
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Grinding noise when it goes to agitate or spin.
gramps Most likely the problem with your washer is worn out motor drive coupling. You can buy it here: If you need help to replace it, let me know. back
Feb 05, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal De
