Question about Toshiba Satellite A60-S1561 Notebook
Bios Flash running windows now dead
I have a toshiba A60-S1691ST now it is no power, it started with a system bios update, i download a new bios build date new than i have, try to run using windows, then after a while windows turns blue screen I cannot do anything but to unplug the power and battery, when i put them back the system is now no power output, I cannot turn on. Is there any solution for this, i need assistance thanks.
  • RonnieR Jul 30, 2008
    board level finding solution, fuses checked ok but still it has no sign of power source, battery pack is fully charge but cannot generate power.
  • 125 Answers
You have a bad flash which means you corrupted the bios you will either have to take to a repair shop and have a new chip installed or buy a new mother board
Posted on Jul 27, 2009
Need updated BIOS
connect a usb desktop keyboard to your laptop using that keyboard
go on the web as usual, if you still can not get the laptop to work
use another computer and, go to your computer makers website
find your computer model and download the manufacture's bios
software burn to a cd then install the bios flash on your laptop as they direct.
Nov 18, 2013 | Toshiba Computers & Internet
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
What's your problem I NEED MY BIOS PASSWARD
To reset the Toshiba BIOS password, use software
ACPI Flash BIOS version 2.30 for Satellite L655
(support for model L655-S5101, etc)
Important
1. This release offers the option to install the BIOS directly from within Windows operating systems. To do so, simply select the 'Windows Installation' option from the Launcher menu, and click 'Ok'.
2. Please close all programs before executing the Windows-based installer.
3. It is REQUIRED that the computer be connected to AC power via the AC adapter, and that the power-save mode is set to 'Full Power' or the equivalent while installing the BIOS.
How to use:
1. Download ACPI Flash BIOS
2. Double-click the file sk2cv230.exe - select install
3. After the install is complete, the image will appear as below. Highly recommended you read the instructions first, or you can select Install from Windows.
4. Click OK. Do you want to upgrade the BIOS - Yes
5. After the update completes, the computer will automatically shut down or restart. Power on the computer if it is off. While the "Toshiba" LOGO is displayed, press the F2 function key to start BIOS Setup. Check the version of BIOS and press the F9 function key then Enter to load setup defaults. Press the F10 function key then Enter to save settings and exit. The computer will automatically reboot.
Nov 17, 2011 | Toshiba Satellite L655-S5101 Laptop
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
Aug 11, 2011 | Dell Dimension 4700 PC Desktop
Bios Faile
bios is always risky update, and toshiba is very well known to stuff up they bios...
first advice, never, ever, update bios from inside of your operating system...
as your computer is already dead, try this method, i cannot recall if you have phoenix or amibios but should work on both:
1. remove power and battery from dead laptop
2. download again bios and unfold it, remember the folder, do not run it!
3. go to this folder and find file with suffix *.rom, rename it to amiboot.rom
4. copy amiboot.rom to usb drive
5. plug usb drive into usb port
6. press and hold fn+b, plug in power cord and press power button
7. if after few seconds you see screen flashing and toshiba logo then returns, you just saved your laptop and few dollars...
8. allow it to boot, switch off, re-insert the battery and use as before.
if this do not work, i am afraid tha tyou need to find some toshiba centre which will flash and re-program bios for your. do not get conned into replacing motherboard! there are non-toshiba repairers which charge between $30 and $100 to flash "dead" bios, toshiba for replacement motherboard want over $300.00
if you find my advice helpful, plese do not hesitate to leave comment and vote 4 fo rme, thanx!
Aug 01, 2010 | Toshiba Satellite P205D-S8804 Laptop
Hi, i was carrying out a bios update on my toshiba equium A60 laptop. it dicided to freeze on me, i tried to turn the power off this didnt work i ended up removing the battery. when the battery was...
That does not sound good. If the Bios update was incompleted and the BIOS ROM was erased then the computer might be dead. You would need to take it to someone who can pull the bios chip and re-burn it using a device or burn the bios to a new chip and then install it. Whenever you are updating your bios you are taking a risk and that is why they tell you to only update when you are having computer problems. And never update a Laptop on battery powern alone. I am not saying that you did I am just giving advice.
Oct 18, 2009 | Toshiba Satellite A60 Notebook
I did a bios flash update on my hp laptop.windows not installing!
wrong BIOS
you are dead in the water, the laptop is dead. unless you can get another same motherboard and swap the BIOS.
other choice is to install your OS from the begining, if the laptop let you into the BIOS.
May 15, 2009 | Computers & Internet
Need large disc support for old emachine, flash bios? or try restore cds?
flashing a bios, can render your machine/motherboard useless.
You should always ensure any bios download is from a trusted source. if you experience a power failure, or an incomplete bios file. your computers as good as dead.
Windows 95/98 only supports disk drives to a certain capacity. if you updated to windows 2000/ME/XP your problems may be solved. I,d certainly try that first.
Bios flashing Last resort, even after finding a reliable bios update. also ensure the bios file is 256mb-512mb or equivalent. as this is standard bios file size.
Finally check that your hard-drive does not have a jumper ( Small white/black ) plastic block restricting the drives registered size.
When you install windows XP, it will ask you if you wish to enable LBA ( large block Allocation ) Select Y ( yes )
Mike @ compurepair.
Mar 12, 2008 | E-Machines eMachines Desktop PC
How do I flash my bios when Ican't get into windows.
If you are totally determined that BIOS is the issue, You can use other computer to make a BIOS update disk which can be a floppy disk or CD-ROM. You need to download related BIOS update and write on the media(CD or Floppy) as bootable, here is the link that you can download latest version of BIOS update
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=1362775&moid=513329&rpn=PSP10U&BV_SessionID=@@@@1226560289.1199954361@@@@&BV_EngineID=ccccaddmmkkhhdecgfkceghdgngdgmm.0&ct=DL&all_docs=false
you will see step by step instruction once you download and open the BIOS updater. I hope it will resolve your issue. Please post for further assistance.
Good Luck
Jan 10, 2008 | Toshiba Satellite P15-S479 Notebook
Toshiba Satellite A60-S1561 Notebook Logo
149 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
