Question about Refrigerators
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
REF DOOR HANDLE LOOSE AT THE TOP. LOOKS LIKE THE CLIP ON THE DOOR IS TIGHT BUT LOOSE IN THE HANDLE
  • Anonymous Mar 16, 2014
    loose door handle
  • Anonymous Apr 01, 2014
    door handle loose
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Posted on Jul 30, 2008
How do I tighten door handle on whirlpool fridge how do I get to the screws model gb2fhdwq02
Hello Tim;
My name is Peter. I am a retired field service refrigeration technician.
You have one of two door attachments:
1.) There are two 3/32" K set screws (Allen Head) at the top and bottom of each handle. Back off these screws until the handle comes off. The is a stud with a screw - tighten and reattach the handle.
2.) There are two brackets mounted to each refrigerator door. One at the top and one at the bottom. At the top of each bracket is a oversize hole. On the back of the handle there are two screws. These screws fit into the oversize hole. Then you push down into a slot to secure the handle. To remove the handle you push up on the handle until the door handle screws are into the oversize holes.
The screws on the door bracket often become loose. Tighten these screws. Sometimes the mounting screws on the door handle become loose as well.
Be careful, if you tighten everything up too much you will not be able to remount the door handle. Adjust the screws for a tight fix
Oct 31, 2014 | Refrigerators
Whirlpool gold side by side door handle is loose.I can't find the way to tighten. IT appears the screws are underneath the rubber gasket, but I am a little wary of tearing it loose without anew gasket.
Most door handles now are front repairable. I can't tell without the model number which style you have, but most units have an insert in the door handle. You have to pry this insert out, to get to the screws for the handle. Some handles actually clip on to the door by sliding the handle up or down to clip it on or off. Good Luck, Appliance Specialists.
Feb 04, 2010 | Refrigerators
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
May 31, 2009 | Fisher and Paykel E522B Stainless Steel...
Problem W/ freezer door
Since you checked the top for level and it was ok you should check the sides for plumb with the level. The fridge has been racked so it is now a parallelogram and not a rectangle. You will have to rack it back to get the door to fit. Basically you will have to push the top of the fridge on the high side until the body is bent back. You will have to eye-ball it.
Apr 30, 2009 | Refrigerators
Loose freezer door handle on my whirlpool side-by-side refrigerat
you should be able to pull straight up on the handle (with force) and it will come loose from the retaining screw. usually its just the retaining clip that comes loose from the door but sometimes you will have to replace the entire handle to repair the unit. if your not having any luck getting it off message me with a complete model number for your refrigerator and i will see if i can get you a little  more detailed information. thx peyton
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door handle loose on 10656542400 kenmore
I got it!!! Okay, the most common problem is the fridge handle at the top is coming loose from the mere fact that the fridge gets opened more than the freezer and people grasp the handle higher than lower. Okay, open the door until you can look at the handle sideways where it attaches to the door. What is happening is the screw that slides into the bracket is simply backing out. Try lifting the handle straight up, only about an inch plus. The bracket is the same on the bottom of the handle as the top. If you cannot get the handle to lift, get a very slim standard screwdriver and push the retaining clip down (away from the handle) so the screw head can get passed it. You may have to push the retaining clip pretty good to get it down. When you have it pushed away from the screw head, lift the handle and it should pop up. Take the handle away from the door and tighten the screw. The screw head takes a torques screw head (star shaped, like a philips but different) Tighten it until it stops the just realign the TWO screw heads into the upper and lower bracket and slide the handle down gently. No problem! You can do it!
Sep 19, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Door handle loose
if it is a side x side the covers side up to come off,some have little taps coving the screws that have to be popped out,mike
Sep 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Oct 15, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
1,087 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
