You need an aerator wrench, Pfister part number 941-031. Several vendors on the web carry this part.
Look on the link below to see how to pull the aerator.
http://www.pfisterfaucets.com/www/ImageAssets/mirror/model/kitchen/hanover/han529-7t/ex-529-01.pdf
I appreciate the page - I actually have that same page. The problem is that I can't figure out out to unscrew the housing. When I unscrew the head and look at the bottom, I cannot figure out how to unscrew it. I have tried with tweezers, and it's not working. That's where I get stuck. I'm sure the aerator is full of debris that I need to clean out.
Please look at the pic below. And please rerate.
Or go to page 6 on link below.
http://www.pfisterfaucets.com/www/ImageA...
This is a big help!!! Do you know what kind of tool I can use to unscrew it - it doesn't screw out easily - or truly at all. I have tried tweezers. Is there a special tool?
Sorry I do not know of a special tool to remove it. What it sounds like is that it is welded on with lime and calicum. I would soak in CLR for a few hrs to see if it will loosen up where you can unscrew.
Did you ever figure this out? I am having the same issue?
We have the same issue, and the links above no longer work.
None of the links in this article work any longer ...
Sorry, hit send too soon ... none of the links in this article work any longer, and we all still seem to have the problem. Help!?!!
