Question about Frigidaire Dryers
Burner lights for about 15 seconds then goes out.
What does the Igniter do? Could that be the problem?
Its a Fridgidaire DGISF
    Genius:
  • 1,028 Answers
Sounds like flame sensor mounted on burner off chance may be burner coils failing but ck flame sensor first
Posted on Jul 29, 2008
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
Jenn-Aire Model CVG4380 gas stove top. Why doesn't igniter work?
Under your knobs are burner switches, 3 of them are the same, so this will be a hit and miss on getting them but possible. Each burner should trigger the ignition system. This will be needed to be inspected to find out which one needs to be replace. If you get the right person to look over the unit they could tell you if it can be repaired. I worked on one about 3 years ago and it worked out fine. Good Luck and I hope this helped.
Apr 11, 2016 | Kitchen Ranges
Furnace continues to short cycle over and over and over...
It could be two things flame sencor needs cleaning of conections not tight or the pressure switch is not working try jumping it out and see if it lights
Jan 15, 2013 | Heating & Cooling
Fridgedaire Oven burner sometimes doesn't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
dddddddd76
May 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Fridgidaire gas stove oven glow lights up but oven doesn't come on sometimes then I smell gas, other times it comes right on with no problems
This is a common problem that happens when the oven gas control valve is sticking. This can be caused by a weak hot surface igniter or a defective gas control valve. One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve stick after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Mar 16, 2010 | Kitchen Ranges
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
I have a JC Penney dryer that is very slow drying cloths. The Igniter and Gas Valve are both working. When I turn the dryer on I can see the burner light but it only stays on for about 15 seconds before it...
HI, First thing you want to check is your venting to the outside. Make sure it is clean all the way out and that it is not pinch/kinked. Please let me know if I can assit you further.
THanks
Vic
May 17, 2009 | Dryers
Explosive Ignition
Check the alignment of the igniter to burner. It should be in the flame of the burner but to one side or just below. Does the igniter glow about 15 seconds prior to the gas valve opening or just a second or two. The igniter should glow 10-15 seconds prior. If the temperatures outside are unseasonably cold, you could be experiencing a gas regulator condition. If so, as the temperature rises, the condition would lessen. Call your gas company to get the regulator tested and gas pressure checked.
Jan 03, 2008 | Goodman GMS90703BXA Heater
Fridgidaire stove
You probably have a week oven igniter. Unplug unit first!!
Remove oven floor. Remove flame spreader. Igniter is attached to side od burner tube. It removes with 2 screws. Remove drawer to access connections. New igniter will come with wire nuts. Cut wires at old igniter, strip back insulation and connect to new igniter. The 2 wires can go either way. Re-assemble and test.
Nov 10, 2007 | Ovens
Dryers Logo
110 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
