Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Compressor stop after about 2 minutes operation
  • 828 Answers
If your unit is air cooled clean the condenser. If your unit is water cooled check for proper water supply pressure.
Posted on Jul 29, 2008
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Ice cream melting
Your freezer is in problem. Please check :
1. Compressor for defective. Please check the sound compressor, if still normal check the refrigerant . Please top up the gas if needed 2. Thermostat for malfunction. This part give trigger to compressor to running and stop. You can test its operation while your compressor working normal. If your compressor is defective, the thermostat will not work. So please fix the item #1 before you go the latter item.
Regards, Jay
Feb 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a baumatic fridge freezer whch appears dead the plug fuse is ok and the electroic panal has been tested ok any ideas
Hello, Kindly check below matters on your freezer:
1. Compressor for defective. Please check the sound compressor, if still normal check the refrigerant . Please top up the gas if needed. If it is totally dead, you need to replace it with new one. 2. Thermostat for malfunction. This part will trigger the compressor to running and stop. You can test its operation while your compressor working normal. If your compressor is defective, the thermostat will not work. So please fix the item #1 before you go the latter item.
Regards,
Feb 02, 2011 | Freezers
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Won't run continuosly.
The first thing that I would look at is the compressor relay. The relay gives extra windings in the motor, power to get the compressor up to speed. It is a small thing that carrys a heavy load. (MORE)
Jul 07, 2009 | Frigidaire 17.8 cu. ft. / 504 liter...
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Danby freezer not freezer
If it is the thermostat that is defective the two wires that go to the thermostat for compressor operation can be connected together which would power up the compressor. Unplug the unit before attempting to connect the two wires. after connection is made plug it back in and if the compressor operates and the freezer comes down in temperature you definitely have a bad thermostat.
Jan 23, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
13.7 cu.ft mdel 970-242520
7 minutes on and 15 minutes off sounds like a good cycle time.
May 15, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
88 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
