My LG VCR doesn't turn on. No power. Fuse looks ok
  • sultanhaji Jul 28, 2008
    Doesn't work on different socket. Power cable is intact.
    Genius:
  • 1,226 Answers
Check carefully the power cable, if no damage then probably the there is a bad fault in the board.
Posted on Jul 29, 2008
  • 6,487 Answers
Check this link its also discussing the same problem and with a detailed solution for a vcr with no power http://www.howtomendit.com/answers.php?id=34032
Hope that helps.........
Posted on Jul 28, 2008
  • Mark Gil
    Mark Gil Jul 29, 2008
    Don't forget to check the link that I gave you that will be helpful for your problem...
  • 19,396 Answers
Check it on a different socket. IF does not turn on at all, or is the power cable or there is a fault in the power supply.
  • Ginko
    Ginko Jul 29, 2008
    Power cable is "intact" does not make any sense, someone need to grab a multimeter and test the power cable to know if it has continuity, if cable is ok, the power supply board inside must be tested. It has an internal fuse that you can just check, to check the rest you need to use a multimeter and to know what you are doing.
    Genius:
  • 1,689 Answers
Have you checked the contacts from the power cord to the board power supply of the appliance? it is possible that you have a loose wire in there?
  • marlon john madrid
    marlon john madrid Jul 28, 2008
    check for any damage on the power cord and then if a circuit tester is available, check if the device's power supply is passing power to the unit, this is so you will have an idoe on which part is to be replaced or repaired.
    okay so the best move will be getting a circuit tester and see if the power supply inside it passing current to the unit.
My dewalt radio dc012 blow fuse in power board,fuse replaced and radio work,after while fuse ok but radio again doesn’t power up
I read this as this: You replaced a blown fuse, the new fuse still looks good but the radio no longer works.
First test the fuse, if it checks out OK then something else has blown in the radio, I check the power supplies first, giving it power and seeing if everything there is still working as it should.
Nov 01, 2017 | Dewalt Audio Players & Recorders
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Nov 01, 2009 | Televison & Video
Doesnt turn on
Either there is a bad fuse under the cover, or the power supply is shot. THe fuse should be a glass fuse which has a wire inside of it. The wire should extend all away across the fuse. If it doesn't than the fuse is bad. If fuse looks ok, the power supply is probably shot.
Jun 22, 2009 | Directv Plus HDTV Receiver with Integrated...
VCR will not turn on.
Remove top cover of the VCR. Then look near the back where the plug-in and power supply is. There should be a little glass fuse. You should keep that fuse and take it to the store and replace it with same exact one. If your VCR can be self-repaired, than this is the only thing you can try.
Mar 11, 2009 | Philips Televison & Video
37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Mar 04, 2009 | LG 37LC7D 37 in. LCD HDTV
LG LH C3603S
Ok thats easy just buy an s-video to rca cable and plug it into the dvd-vcr combo in the av in and then turn the vcr on to av 1 2 or 3 what ever you pluged it into then when that is all turned on and pluged in then you plug it into your laptop and wait it should switch over automaticly
Jun 22, 2008 | LG V194H DVD Player/VCR
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
