Question about Acer Aspire 5100 Notebook
Power or boot failure
I try to boot my acer, but continue to get an error message that the media test failure to load, Message PXE-E61.
    Sergeant:
  • 359 Answers
PXE is a common term when a computer is trying to do what is called a network boot. you probably have a bad hard drive and the computer sees there is no harddrive and is trying to boot from a pxe server off of a network.
Posted on Jul 29, 2008
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: PXE-E61: Media test failure, check cable
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Posted on Aug 31, 2008
budmrtn
  • 11361 Answers
SOURCE: i GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
Posted on Nov 04, 2009
  • 744 Answers
SOURCE: PXE-E61 Media test failure
See this on-line thread from other users. I'd be leary about the posts that advocated hitting the laptop...
http://www.nocrash.com/ncbbs/msgs/3247.shtml
Portable computers can suffer from bad connections easily, so the first thing you should check are that all cables and other connections are tight and seated firmly.
Posted on Mar 31, 2010
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
My acer aspire 5538G won't boot, i get a message saying error PXE-E61: media test failure check cable PXE-MOF exiting broadcom PXE ROM operating system not found.. and i am unable to use disk to disk...
Your computer is attempting to boot over the network (something that only works with a server on the network) PXE E61 Media Test Failure Error
You can get this message if the boot device order is wrong in your computer (go into bios and check) but more often, the computer has tried to boot from the hard drive and dvd and failed before trying to boot from the network. It sounds like the hard drive has been failing for a long time and is now so bad the disk to disk no longer works. Replace the hard drive and reinstall using the recovery DVDs you created. If you didn't create them, you may have to contact Acer for a set.
May 05, 2017 | Computers & Internet
Mar 31, 2010 | Acer TravelMate 2300 Notebook
I GOT THIS MESSAGE TODAY PXE-E61 MEDIA TEST FAILURE CHECK CABLE WHEN I TRIED TO BOOT MY ACER ASPIRE 5630 THIS MORNING. IS THERE A QUICK FIX FOR THIS? EXITING BROADCOM PXE ROM OPERATING SYSTEM NOT FOUND
Nov 04, 2009 | Acer Aspire 5630 Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Aug 31, 2008 | Acer Aspire 3680 Laptop
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Acer Aspire 5100 Notebook Logo
193 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
