Question about HTC TyTN Smartphone
Unresponsive htc tytyn touch screen
Hi ,
my tytyn 2 touch does not seem to repond to taps
i have tried soft reset , hard reset , removed the battery and replaced , did a clear storage ... went through clibration several times ... seems to recognnise the stylus when calibrating then just goes into calibration mode over and over ... maybe software issues ... i have tried all the suggestions , nothing works ... phone only 4 months old.
btw , i have removed the screen protector and cleaned the screen ... heeeeeelllllppppp !!!!!!!
  • 1 more comment
  • jpondman Aug 28, 2008
    My screen is unresponsive most times and inaccurately responds to stylus taps when it does work. So using the stylus is quite frustrating. I keep cleaning the screen apart from that , i don't know what to do.
  • Anonymous Feb 17, 2009
    I ahve the same problem too!
  • Sir Smoooth May 19, 2009
    hey, I'm having a similar problem. I was using my htc tilt while i was in the bath but I was very careful not to get it wet. Now the touch screen doesn't work. I can't do the screen alignment or anything. The phone works fine if I'm not trying to use the touch screen. I'm wondering if anyone else has ever had this problem or if anyone knows what I can do to get the screen working again. Any help/info would be greatly appreciated.
    Adam
I had the same problem, it turned out to be dust caught just under the plastic at the edge of the screen, a finger nail got it out or you could be fery careful and use a sharp flat knife. hope that helps,
Posted on Aug 27, 2008
How do u reboot the htc one
If there's a problem with your screen or you're otherwise unable to do a factory reset via the settings menu, then you can use the hardware buttons to do a reset too. Simply turn your HTC One off, then press and hold the Volume Down and Power buttons. Continue to hold them until you enter the H Boot screen.Aug 23, 2014
How to hard reset the HTC One - AndroidPIT
https://www.androidpit.com/hard-reset-htc-one Feedback About this result
HTC One (Verizon Wireless) - Restarting HTC One (Soft reset ...
www.htc.com/us/support/htc-one-verizon-wireless/howto/394150.html
  1. Cached
  2. Similar
Restarting HTC One (Soft reset) If HTC One is running slower than normal, is unresponsive, or has an app that is not performing properly, try rebooting and see if that helps solve the problem. If the display is off, press the POWER button to turn it back on. Press and hold the POWER button, and then tap Restart.
HTC One - Resetting HTC One (Hard reset) - SETTINGS & SERVICES ...
www.htc.com/us/support/htc-one/howto/365649.html
  1. Cached
  2. Similar
Performing a factory reset from settings. Go to Settings, and then tap Backup & reset. Tap Reset phone. Tap OK.
How do reboot the htc one Google Search
Nov 08, 2016 | HTC Cell Phones
STARTING UP PROBLEM WITH MY SAMSUNG GT19100
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Apr 29, 2014 | Samsung Cell Phones
SAMSUNG GT19100 STARTING UP PROBLEM
Hi Adil,
Apr 29, 2014 | Cell Phones
My Samsung intercept won't load past the flashing Samsung so I was trying to factory hard reset it and it won't even do that I attached a photo of what it says
Hi Latonya,
Apr 28, 2014 | Cell Phones
How to reset my phone password easily?
Hi Ronquillo,
Apr 28, 2014 | Samsung Galaxy Y Gt-s5360 Pink Factory...
I want to reset a HTC HD7 but i dont know how. can you help me?
1. From the Start screen, tap wp7arrow.png in the upper-right corner.
2. Tap Settings.
wp7settings.png3. Scroll down and select About.
wp7about.png4.Tap the Reset your phone button.
windows-phone-7-reset-button.png5. Confirm your selection by selecting Yes. Then tap Yes again.
Your HTC HD7 will then go through the process of resetting to factory default settings.
Option 2 - Resetting using the hardware buttons
You can also use the buttons to perform a hard reset. This comes in handy if the screen is frozen and you can't access the phone.
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Mar 08, 2011 | HTC Cell Phones
My htc touch pro 2 smart phone screen is locked and seems to be frozen, I have reset and removed battery with no results how can I unlock this screen?
It might be a hardware problem, if you already tried the soft reset (removing the battery) then the next step is to hard rest. This will lose all your information and settings, the phone will be like the first day you took it home (and hopefully the screen will work)
First make sure the phone is off, then press and hold the TALK/SEND, END and POWER buttons until you see a message on the screen.
Once the message appears release the buttons and press the volume up key for a hard reset.
May 31, 2010 | HTC Touch Pro2 Smartphone
Htc touch
HI,
Its time to take it in for service. Touch screen needs to checked. There is nothing much you can do apart from what you have done on your own. It requires special tools to open.
I suspect the Touch screen has to be recalibrated.
Thanks
Mandeep
Jun 09, 2008 | HTC Touch P3450 Smartphone
TYTN2 buttons not reponding - screen navigation fine
If a soft reset does not fix it,
Try a full hard reset:
Soft reset: Use the stylus to lightly press and hold the RESET button on the bottom of your device.
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Another Option if one of the SOFT KEY's is bad: START/SETTINGS/SYSTEM (tab)/CLEAR STORAGE.
Dec 05, 2007 | HTC TyTN Smartphone
HTC TyTN Smartphone Logo
572 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
