Question about Kenmore 24032\24036 Top Load Washer
Washing machine My Kenmore model is 110.92480200. Problem is: It fills with water, but nothing is telling the water to stop. It will keep running, as the timer doesn't rotate. Agetator doesn't work no matter where I turn the dial, but water will keep coming in. The drain/spin mode does work and the dial turns at that point only. Could it be the timer? It costs over 100.00, so I kinda want a second opinion. Thanks, Steve
  • 1 more comment
  • pqzm Jul 29, 2008
    You just saved me at least 100.00. If I had replaced the unneeded timer and still had problems, I would of paid a repairman to come over, or replaced with a new washer. You may have saved me around 500.00! Instead it cost me nothing and my wife thinks I'm a genius! Thankyou!
  • otisfields Aug 01, 2008
    Water level on works at large load level. Will not stop at small and median load levels.
  • kokobean_200 Nov 11, 2008
    On all cycles the water level will only go to the low mark, if it is on med or large load setting the water will come in a drain off
  • 550 Answers
Remove the left and right edge trims on the control panel
remove the phillips screws under the edge trims
raise control panel ~1 inch and flip over backwards.
  • ensure air tube is attached( water level sensor operates off air tube from bottom of drum to control body, (bottom is not loose or there would be water all over the floor))
  • Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
  • ensure wires are connected to control body.
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed just dont shock yourself on the cable connectors
  6. test, adjust, test adjust. (water level switch may need to be flicked hi-med & back to test adjustment
  7. if no effect replace water level sensor body
The water level switch body contains a small spring that is not really up to the job and stretches over years,
do this repair, on call, no parts, takes 15 minutes,, 3-4 times a month
Posted on Jul 29, 2008
  • AlmostBob
    AlmostBob Jul 29, 2008
    Please the wife, bonus,
    D'os vdanye
Kenmore top loader mod. 110 29522801 does not run after filling with water. The lid switch could be bad. Are there other problems that should be addressed?
if the unit is filling with water it is not the lid switch because it will not fill with water if the lid is open
problem areas are the water level switch is not energizing the wash cycle as well as switching off the incoming water
if it is stopping the water but nothing else , have a technician check the program board
Jan 13, 2017 | Kenmore Washing Machines
Fills with water will not run no motor sound nothing
top load or front load .might be the lid switch /door switch . or the control board make,and model usually helps us help you
Oct 24, 2015 | Kenmore Washing Machines
Kenmore Heavy Duty 80 Series Extra Capacity Plus Model# 92480200. The washer will begin to fill and will not stop filling regardless if water level setting is on low, medium or high and will overflow and...
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 30, 2010 | Kenmore Washing Machines
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
May 03, 2010 | Kenmore Washing Machines
The wash machine will fill but wont stop filling
If it stops filling when you turn it off, the water level switch is malfunctioning. If the water runs in regardless, the water inlet valve needs replaced.
Dec 28, 2009 | Kenmore Washing Machines
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
349 people viewed this question
Sal De
fordexpert
Robert Rankin
