Kelinator ESC wahing machine spinning ok but filling too slowly. Not doing wash cycle
    Sniper:
  • 68 Answers
If your washing machine is filling too slowly, then you probably have a clogged screen on the back of your washer. To check this: Turn off the water supplies(both hot and cold). Remove the hoses at the back of the washer. Check the screens for debris(i.e. rust, dirt, scale, etc.) The screens will be pushed into the back of the washer where the water enters the washer. Debris can come from a variety of places: #1 Deposits coming off the sides of your pipes.(Older homes) #2 Repairs done to your plumbing lines, or the cities lines.
If these screens are clear of debris, I would then check the water flow out of the hoses. Take each hose with the end pointing into a bucket, and turn on the water to allow a full flow. This will also flush each line of debris. There could also be a number of reasons that there would not be full flow out of the supply lines: #1 Debris stopping up the line at the shut-off is one of the main causes.
If you have debris stopping up your screens and shut-offs, it will most likely stop up your aerators on your faucets, and your shower heads too. It is also suggested that you check these.
If you are getting debris in all these items, I would recommend that your lines get flushed. You can do this, but many times it is easier to have a plumber do this. If you do not know what you are doing, it can get very wet, and time consuming.
Good Luck
Posted on Jul 28, 2008
Set it going, fills up ok, goes through washing cycle but after spinning and then filling up for next cycle it overflows
Rather hard to understand your problem from the wording in the question but what I understand to be the case is that your tub fills up with water and overflows after the cycle is finished. Perhaps overnight water slowly fills the tub. This is due to the water inlet valve not shutting off all the way. The Inlet valve assembly needs to be replaced.
Apr 27, 2011 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
The lights are coming on but nothin is happening what do i do ?
wahing machine must of filled but then stopped on wash wont spin or rinse lights all on any ideas
Mar 13, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Oct 07, 2009 | Washing Machines
AWM6140/3 Wahing machine
it's a prgramme timer issue mate, you either need the timer flashing with updated software or a replacement timer
Aug 24, 2009 | Whirlpool AWM6140 Front Load Washer
Timer
Jimbo, thanks for letting us know the way you solved the problem. I am sure it will help other people who will face it in the future.
Jun 06, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
