CANON IMAGECLASS MF4150
HI, CAN SOMEONE TELL ME HOW I CAN GIVE FAX TONE AND/OR SEND A FAX WHILE I AM ON A PHONECALL, I'VE SEARCHED IN THE INSTRUCTION MANUAL AND COULDN'T FIND AN ANSWER!
    Genius:
  • 1,056 Answers
If you are using the phone while trying to send or receive a fax, it will not work.
There were some devices out that would allow you to do this, but they never really worked that well.
If you want to be on the phone, and send or receive a fax, you will need a second line for the fax machine, or you need to use a service like eFax (it sends a fiax like sending email)
Posted on Jul 29, 2008
SOURCE:
How to send fax? activity report shows MODE:tx g3 and resust shows:ng00ff
The result NG 00FF means that the machine has tried to send a fax and gone through it's 3 redials and ended up failing to transmit. You do not say if you can receive faxes?
1. Make sure the telephone line you are connected to will make an outgoing and an incoming call. try this with a good working telephone.
2. Make sure you are using the genuine canon telephone line lead.
3. Make sure the line lead is plugged into the LINE socket and NOT the TEL socket.
4. Press the HOOK button on the fax and you should hear the dial tone through the speaker.
If all the above works and is correct then the machiine has a problem but i doubt it as you are getting 00FF and if the machine was at fault you would get a different error.
I reckon the above should cure your problem.
Good luck.
Jul 09, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
I want to fax a PDF file with 52 pages and its says memory full
There is insufficient memory for 52 pages. Send 26 then send the other 26 and that should work.
Jun 02, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
How can I install my printer (Canon imageclass mf4150) without the cd and no needing fax capability? I tried installing manually but won't work any advice?
You can download the drivers for Canon MF4150 from Official Canon Site. Click here and go to 'Drivers & Downloads' - Select the Operating System you have on your PC (e.g. Windows XP) and you will get the drivers and software for you printer.
GoodLuck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
Dec 10, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
When i press Scan>Start, it doesnt. Why?
Most all in one machines are built around the fax if you send or receive a fax then all function should work. sounds strange i know, but 90% percent of time it solve this issue.
Sep 19, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Data processing light keeps flashing in fax mode
Unplug your USB cable and the fax should start working. If this fixes the issue, it could be a problem with your USB cable or hardware.
Mar 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF4150 Fax Problem
on the settings, it needs to be set for a certain number of rings, and also on auto receive
Jun 14, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
107 people viewed this question
k24674
Marvin
Marvin
