Register and download the manual for free at retrevo.com PROTECTIVE FEATURE In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points. Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit. Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.) Make sure the volume does not exceed the level that the unit is capable of producing. When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising. After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance. If this symptom recurs, request service at your nearest service center. In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
SOURCE: Standby light is flashing rapidly and I can't turn
RECEIVER MARANTZ SR7002, FLASHING THE STANDBY about 8 times per second and will not start, HELP
