Question about NetGear WGR614 Wireless Router
Wireless modems How do I check if wireless modem is bad. not connecting to internet but my pc is showing that I am connected. netgear used to connect, then started to jump out and now not connecting at all
  • 928 Answers
To be able to check it you must do a reset then reconfigure the modem. Can you give me the model number of your wireless modem so I can give you more steps. Also, when you connect your computer to the modem do you get a network cable unplugged error in the lower right corner of your screen, if you do try changing ethernet cables if the same thing comes up then that means that there is a problem with the ports on the modem.
Posted on Jul 28, 2008
  • 6,487 Answers
Connect your computer via ethernet cable directly to your modem then power off the modem for 30 seconds that way should be able to go online if the modem and internet is working fine from your ISP.
Hope that helps...........
Unable to connect EpsonTX710W Printer viaNetGear DG384
On your Laptop go to Control Panel-> Printers-> and then add printer. Select the option of network printer and search for your printer. If found add it.
Or Else check the ip of printer from ports tab in printer properties on desktop computer ans search your printer with ip address on Laptop.
Jun 01, 2010 | NetGear DG834G Router
Cannot connect to internet using wgr614 router. connection is good without router. with router connected, internet lite blinks.
To use a router with a DSL modem or cable modem, you need to connect the modem to the router at the WAN port and then connect the PC to one of the router ports. If the cable you have been using between the modem and PC is lableled as a cross-over cable, it is the wrong type of cable for the router connection. Use a straight through cable to connect the modem to the router.
If you do not have a manual for the router, here is a link to the router manual online: http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
The cross-over cable could be the problem (typically yellow cable).
Jan 20, 2010 | NetGear WGR614 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Jul 24, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
Wireless modems
Several ways to find out. One is to connect to the router's web based settings and find out if your service provider assigned an IP address to the router. Even though it states that you are connected to the network doesn't always mean you are connected to the internet. Within the settings of the router, under status you should be able to see the IP address assigned by the provider. You can release it and renew it to make sure you are receiving the latest IP that was sent from you provider. The second way to see if the issue lies with the router....bypass the router by connecting one of your computers directly to the modem. If you are connected to the internet immediately then you will know the problem lies between the modem and router. To get into the web based settings of the router type 192.168.0.1 or 192.168.1.1 into an open internet explorer address bar. Window should pop up asking for username and password. admin should be used for both. Contact me if you any other questions. Just to clarify though, router's are prone to lock-up or losing signal due to interference and age.
Good Luck.
Jul 17, 2008 | NetGear WGR614 Wireless Router
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
NetGear WGR614 Wireless Router Logo
96 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
