Question about Digital Audio DA8012 12" Subwoofer Car Speaker
Wiring How do you wire up a DA 12" sub to an amp? I have 2 + and 2 - on each side. No matter how I hook up the wires, no sound comes out. What am I doing wrong?
  • 27 Answers
1st make sure your amp is coming on. Use another speaker that you have heard play to test it.
Next test the woofer with a 9 to 15 volt battery. Touch the battery leads quickly across the + and - on one side at a time. The speaker should move and make a pop on both voice coils.
If the amp plays and speakers play, then you need to know the power rating and impedence stability of both amp and speakers. That will determine how they are wired up.
Posted on Dec 18, 2008
I have 2 12" kicker solar baric squares L7 hooked up to a kicker cx 1200.1 amp as soon as I turn bass knob up it cuts out and amp goes into protective mode plus I have a 3 microfarad copasitor hooked up...
Sounds like your wiring is giving you the wrong impedance,Check crutch field advisors website for sub box construction and detailed wiring instructions.
Aug 22, 2014 | Car Audio & Video
Ok so i have a kenwood set up , 2 12 inch subs and amp, all the fuses are fine the connections inside the box to the subs are fine , the head unit is all hooked up and fine there is no cuts in any of my...
It does sound like a problem either with the amp itself or the wiring. Since the wiring is the easiest thing to check and cheapest to fix start here.
1.Make SURE the ground wire is secured to the frame of the vehicle.
2.Make sure the remote wire is hooked up properly.
3.Check the component/rca cables
4. Check the settings on the amp itself
Post back and let me know if you find anything wrong with one of those troubleshooting ideas.
-Daniel
Aug 09, 2011 | Car Audio & Video
For da orion 2500d, what would be the difference between 10'', 12'', & 15'' orion hcaa subs besides a matter of price and inches? I have two of the orion 2500d amps and am ready for the subs. I would...
I honestly would go with 2 12 inch dual 2 ohm subs and wire them one per amp. That will give you a 1 ohm load to each amp and will give the HCCA's 2500 rms per sub... It will be stupid loud... 10s hit tighter than 12's usually and 12's tighter than 15's but u will get more air movement out of a 15 than the 12's and 10s... but... 2 10's require say a 4 cubic foot box to perform well... 2 12's require a 5 cubic foot box to perform well and 2 15's require about 7 to 10 cubic foot to perform to their fullest... no matter what if you put a sub in a box that's too small it will not perform or sound like what you want it to... go 2 12's and like a 5.50 cubic foot box or a 6 cubic foot box and you will love it...
Dec 01, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Amp turns off
what ohm is it running at? if you have all three hook up it parallel then its to low of ohms and it would be louder if you unhook your 10" sub as it moves differently form the 12"s and it cancels out some bass. but if you want it then you have to change the wiring around a bit. take the positive wire off a 12 and put it on the positive side of the 10 and then take the ground for the 10 and hook it up to the positive side of the 12. so you should have one wire from the amp going to the negative side of the 12 and one going to the positive side of the 10 and a jumper wire from the 10 to the 12. and if it still shuts off then you have bigger problems.
Sep 25, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
How do you hook up 2 12" L7's to a kicker 1200.1 amp?
You have a 2 ohm stable amp, and dual voice coil subs.. The L7's come in both Dual 4 ohm, and Dual 2 ohm, so you have to know what impedance your coils are prior to wiring. HERE is a nifty little guide that will show you how to wire your subs. DO NOT WIRE THE SUBS LOWER THAN 2 OHMS ON YOUR AMPLIFIER!
Aug 23, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will happen...run another power wire to the alpine and this should solve the problem.
Jul 25, 2009 | Rockford Fosgate Punch 301S Car Audio...
Subwoofers pop then immediately produce no sound
Sounds like the two subs wired together might be too much of a load on the amp and it is shutting off. Try wiring the two subs in series. That will reduce the load on the amp but will conversely put out less power. Less is better than none though. In any case check your amp to see what the lowest ohm rating it can see, that ohm rating is where you want your subs and if faced with a choice of either going under (lower numerically) or over (higher numerically) GO OVER!-it is much safer.
Here's an article I wrote that can help explain how to wire the subs to the amp.
OHM LOADS, SUB WIRING, OHM RELATED POWER OUTPUT
SERIES SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the negative pole of the other voice coil (on the same sub). This will leave you with a positive pole from one voice coil and a negative pole from the other giving you the two leads that will be hooked up to the amplifier or other subs. When wiring in series, the ohms will go up numerically, and the load on the amp will go down. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
PARALLEL SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the positive pole of the other voice coil (on the same sub). Then wire the negative to the negative in the same way. You can then wire to the amp or other subs. When wiring in parallel the ohms will go down numerically, and the load on the amp will go up. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
MULTIPLE SUBS USING SERIES AND PARALLEL WIRING
In order to match your amplifiers ohm rating you can use parallel and series wiring together, just keep things even for power distribution and to avoid phase issues.
Example: I have two “Type X 12” subs” that have dual 2ohm voice coils and have to match my “Amplifier X” ohm rating of 2ohms mono. In this case, I would wire each subwoofer in series (giving me a 4ohm load), and then wire the two subs in parallel to get my 2ohm mono load. When wiring multiple subs just, treat each sub as a voice coil and wire accordingly.
POWER OUTPUT AND OHM LOADS
For example if “Amplifier X” can make 100watts@8ohms, it would make 200watts@4ohms and 400watts@2ohms. However with every drop in ohms the amplifier is put under more pressure. It starts to create a lot of heat, distortion figures begin to climb, damping rates drop, and some amps even throw power spikes when clipping. SO BE SURE TO CHECK YOUR AMPS RATING AND DO NOT EXCEED IT!
-Dynami
Apr 04, 2009 | Alpine Car Audio & Video
Wiring
You may be surprised to learn that even though there is a negative and positive on the sub it usually dont matter all that much because that amp allows you to switch the polarity of its outputs to allow your mids to sound better... anyways on to your question To wire a sub it depends on how many you have, if they are dual or single voice coils, what impediance your amp is stable at. Tell me what type of amp you are hooking this subwoofer up to and how many are being connected. And ill try and give you the best way to connect the sub(s) to your amp.
Mar 25, 2007 | Rockford Fosgate RFP 2418 Car Subwoofer
Pioneer amp and sub problems
That's a 4-channel amp, not a 2-channel, which makes me wonder exactly how you have it hooked up to your sub. Is the LED light on the amp coming on? How many subs do you have hooked up to it, and how is it wired?
Mar 04, 2007 | Pioneer GM-6200F Car Audio Amplifier
Amp is on but nothing coming out of Sub
If one amp works inthe same place same wiring same hookup, and the other one dosent, It got to be a bad amp or the way its being hooked up. Make sure the standby is hooked up properly. Get the wiring diagram for instalation for both amps and look at them side by side. If the dead amp is supose to work then Im sure by comparing hookup your gonna say "AAAWWWWW I See Now!!" Good Luck
Jun 23, 2006 | Legacy 2 CH 1800W RED AMP Car Audio...
Car Audio & Video Logo
111 people viewed this question
Top Digital Audio Car Audio & Video Experts
Tom Chichester
Deandre Smith
Deandre Smith
Level 1 Expert
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
