Im having trouble charging my mp3 player using the usb port on my computer it will come on long enough to show low battery then it shuts off
Maybe u should hold the middle botten the play botten the skip bottens
Posted on Jul 28, 2008
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
It was kept idle for 4 months.when power button is pressd the screen shows "battery is too low system shut down".when charging is tried through PC USB port there is no proper charging
Not all computer USB ports put out enough current to charge batteries. If you have another USB port on your computer, try that. Try another computer. If that doesn't work, try an AC-to-USB charger, as you might find for cell phones.
Nov 17, 2010 | SanDisk Sansa e260 MP3 Player
My i pod is not getting charged eventhough it is connected to computer.
SOME LOW POWER USB PORTS MAY NOT PROVIDE ENOUGH POWER TO CHARGE THE PLAYER
The battery can also be charged using an AC adapter
Mar 04, 2010 | SanDisk Sansa e260 MP3 Player
Dell DJ Ditty fully charged but shutting off due to "low battery"
charge your player and reset and try again if not works
then replace battery of your device that is damaged
Dec 25, 2009 | Dell DJ Ditty MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
Low battery
In this case wat u can do is on the Mp3 player itself u will see a slide switch which will say Hold/Unhold or Lock/Unlock............ Just make sure it is not Locked or On Hold and then try to charge it............. Will Work Fine.......... Goo Luck
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
Help me
Hello : Try to charge it from other PC, some USB PC ports have not enought USB current to charge the battery fully.
Apr 18, 2007 | SanDisk Sansa e250 MP3 Player
67 people viewed this question
 Grubhead
Grubhead
