Sounds like the drive might be taking a dirt nap.
You've a lot of really great freeware options for file recovery if you're running Windows. Notable apps include Undelete Plus (original post), PC Inspector File Recovery (original post), and Restoration (original post).
Undelete Plus is the most user-friendly option of the bunch, with
advanced filtering options that make it easy to find your needle of a
file among the haystack of deleted garbage, but in my tests I found both
Restoration and PC Inspector File Recovery to be more effective at
recovering files. (Of course, your mileage may vary.) As an added bonus,
the bare bones Restoration is portable, which makes it an excellent
addition to your thumb drive.
All you can do is place the hard drive into a Ziploc bag and seal it. To be extra safe you can also place the drive in an anti-static bag then place it into a Ziploc bag. Place the failed hard drive into the freezer for around two hours (you can try doing it longer if two hours does not do the trick).
Sounds like the mechanical inside the drive is failing, freezing it can help with that
I will give it a go...fingers crossed, thanks socialone
No, it didnt work either after freezing it..
Thanks Socialone75, so you think the external hard drive cannot be fixed?
How am I able to retrieve the files from the drive if it is not spinning? Thanks
