Question about Sony KV-27FS16 27" TV
TV turns on but no picture and clicking noise. Use to come on after 8 or so attempts but does not any longer.
    Problem Solver:
  • 7 Answers
It may be 1 or more Capacitors that build up a charge to start it.
Posted on Sep 22, 2008
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
Picture image is unsettled when you 1st turn on the TV - Eventually gets better after warming up for 15 minutes. Rear projection HD 56" screen - About 8 years old.
LINES or noise from left to right etc. This is a classic problem in a lot of these sets--that this clears up after a while is also typical---the period will gradually get longer and longer for it to become normal.
This set uses a Hyper board for all signal from all inputs---about two dozen tiny surface mounted filter capacitors on that board---they dry out and lose value---flat caps will when hot attempt to regain some of the value they should have.
Board is no longer available from Toshiba, only way to fix is remove one in set and send out for repair to someone like PTS Electronics.
I have seen experts try to replace the tiny caps--usually several are off value or open---cheaper to send board out. Last one I saw cost was about 200 for rebuild, keep in mind same problem will happen again in 5-8 years.
Let me know if you have questions and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Toshiba 65H84 65" Rear Projection HDTV
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
TV will not turn on. It makes a nonstop clicking noise.
Sounds to me like the high voltage power supply is attempting to fire off the metal halide lamp without success.
Nov 24, 2008 | Philips 55PP9352 55" Projection Television
TV requires multiple attempts to turn on
You have discribe a problem that sounds like a powersupply cap. It may also be more than one. LOOK at the board very hard for bad caps.
Jul 26, 2008 | RCA D61W20 61" Rear Projection Television
Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Oct 10, 2007 | Toshiba 42DPC85 42 in. EDTV-Ready Plasma...
TV will not switch on
It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
Jan 29, 2007 | Philips 32PW6506 32" TV
Sony KV-27FS16 27" TV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
