Question about Dometic NDR 1292 Refrigerator
NDR fridge Cold on the Freezer side not the other side
We have a 1999 Fleetwood Bounder the NDR 1292 fridge.
THe freezer get cold but not the other side. This just started.
We have had the RV for 6 weeks in Phoenix Az. all of a sudden the cooler side want get below 67 degrees and that it.
What sholud I do??
Preston
beauhill@getdistinctive.com cell 602 904/1183
  • Anonymous Mar 18, 2014
    will not stay burning on propane while traveling since recall
  • 51 Answers
If this started in Nevada i presume it was hot there.It sounds like you need a fan installed on the back to increase your air flow across the coils. The fan is much like the one on your computer.
Posted on Sep 08, 2008
Freezer gets cold but not refrig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Dometic NDR 1292 Refrigerator
I have a side by side. The freezer get's cold (-16) but the refrigerator will not cool down.
This is usually a stuck damper (which could be the damper itself or the control board) or a bad thernistor (temperature sensor) on the fridge side.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Dometic NDR 1292 Refrigerator
Food is freezing in the refrigerator the freezer side works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jan 20, 2010 | Dometic NDR 1292 Refrigerator
Freezer works but fridge dosent get cold
sounds like you need to replace the electric heating element
Jul 17, 2009 | Dometic NDR 1292 Refrigerator
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
Same problem freezer is ice cold and the fridge is warm.
Make sure that the knob that controls the opening of the vent so the cold air in the freezer get to the refrigerator is operating. If it does, I don't see any reason why the refrigerator should not work.
Jun 30, 2009 | Dometic NDR 1292 Refrigerator
My dometic fridge doesn't cool some times but the freezer works
I don't know what type of fridge you have side by side or top mount or bottom mount but what every it is sounds like the air ducts are blocked with ice or the air damper is not working.
Apr 02, 2009 | Dometic NDR 1292 Refrigerator
Cold freezer warm fridge
The only thing I can say now is to make sure that this unit is level. After that you can check to see what model refer you have and we can go from there.
Dec 30, 2008 | Dometic NDR 1292 Refrigerator
Dometic NDR 1292 Refrigerator Logo
383 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
