Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Bluetooth problem how do i pair my bluetooth with a new phone
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (serched bluetooth serched device) once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to clear bluetooth to add new device?
You can pair BT150 with up to four phones or other bluetooth devices.
Before you pair it with a new phone, use the bluetooth menu on the phone it is currently paired with to disconnect it.
The passkey is 0000
Jan 31, 2011 | Jabra BT150 Wireless Headset
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Hi I cannot pair my new phone by bluetooth My new
try deleting some of the paried devices from the settings menu to make room for a new phone.
Dec 27, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Motorola HS500 Headset
I had the bluetooth paired with my red motorola raza, I just brought the grey motorola raza and I cannot get the bluetooth to pair with my new phone. It's the same exact phone, just a different color. The bluetooth is fairly new. Now the bluetooth wont come on at all since I tried to pair it with the new phone.
Dec 29, 2007 | Motorola Mobility HS500 Wireless Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
246 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
