Question about Panasonic CT-36D32 36" TV
Please Help !!!!!!!!!!!!!!!!!!!
I have a Panasonic CT-32d32 Stanard tv,and I can"t get no souund.It's not on mute, but my TV screen says Speakers off. what can i do ?
1. hit menu, use right arrow and select 'Audio'.
2. hit menu use down arrow to scroll down and select 'Speakers'
3. hit right arrow to scroll thru options, select 'on'
4. hit menu 3 times to save and exit back to picture
Posted on Jan 17, 2009
WHY DOES THE VOLUME MUTE WHEN I USE HEADPHONES
The TV's speakers are muted once a headphone is inserted.
Apr 03, 2014 | Panasonic CT-36D20 36" TV
I have a panasonic ct-32d32f tv and it will not turn on
Check its horizontal scan output transistor. Replace it with same number and check. If this transistor is faulty, this kind of fault can occur to most Panasonic TVs. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 10, 2013 | Panasonic CT-32D32 32" TV
Tv goes on and off randomly by itself
unbalanced power supply, or damaged energy cable
Apr 18, 2013 | Panasonic CT-32D32 32" TV
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
The speakers are partially muted thru the TV mode.
you mean with all tv channels too? there might be an attenuation setting somewhere that has to be de-activated. Check the manuals. hope this helps and pls come back for a feedback
Aug 19, 2009 | Toshiba Regza 46RV535U 46 in. LCD HDTV
No audio at all
there is no internal switch inside the tv to fix the problem. have you unplug the tv for 5 minute and see if it reset. if that don't work is in internal circuit sound board unit, sound is a bit difficult to diagnose and fix yourself, Any tv shop can fix the issue under 100 buck replacing the board, or you can bypass the sound by using RCA out put from tv than to an amp OR spend 50.00 and get a computer speakers that has an amprefier built into it and plug it in head phone from your tv and you can control the volume from computer speaker unit. My friend has the almost the same issue that the tv wont change channel by remote or from tv unit itself, so we use cable box and the remote to by pass the problem. I hope that help a bit..good luck!
Jul 10, 2009 | Panasonic CT-36D32 36" TV
Closed Captioning no longer works
check for the knub OSD on your remote to press it or at the menu select on screen display on
Apr 20, 2007 | Panasonic CT-27SF25 27" TV
Panasonic CT-36D32 36" TV Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
