Question about Alpine Car Audio & Video
My cd player shuts off when the music is too loud it is a cda-9887 and when it was in my friends car with the same speackers it did not turn off
The radio could be drawing too much power from your battery which is causing it to shut off
Posted on Jul 29, 2008
I have a cda. 9887. It powers on but gets no sound from any of the speaker wires. What could be wrong. What can I try.
Most Alpine CDA units come with an option to turn on/off the internal amplifier in order to give you better sound when connecting an external amplifier. Try turning on IC
Aug 15, 2011 | Alpine CDA-9887 CD Player
My cda-9887 does not have a bass/treble setting. Only fade/balance
In the initial stage of the set up your 9887 the stereo is set with an Equalizer (parametric or graphic), Until you use the Imprint set up module to Tune your car you wont get bass / treble controls. Also after Tuning with Imprint you will lose the EQ function, and it will only be B/T.
Nov 02, 2010 | Alpine CDA-9887 CD Player
Alpine 9887 no incoming power supply. Incoming vcc checked ok at conector level, 10 amp fuse block not blown
did you check power at both the red and yellow wires? also, make sure you have a good ground.
Sep 10, 2010 | Alpine CDA-9887 CD Player
Alpine 9887 displays INTERRUPT in 1998 Honda Accord EX
i think its the wires mate.
if you wnt to try something Discconect the battery of the car. let it 10 minutes and then plug it again. if it not work
the problems are the wires.
Check on the web for the distribution of the colors and wires from ur stereo and from the car.
cheers hope that help
Apr 25, 2010 | Alpine CDA-9887 CD Player
Speakers dont work with CD, but work with radio.
I just had this problem with my e34 bimmer, just connect the blue wire to with the red wire (apparently the 9887 shuts off the antenna when the radio is off). so in my case, bmw thought it was a good idea to wire the two together, which means you go to CD and the Deck shuts off the amp, killing the speakers.
Nov 15, 2009 | Alpine CDA-9887 CD Player
Ipod control?
You can purchase the KCA-420i and connect it to to the ai-net port behind the headunit. This will allow you to send signal from your ipod to your alpine headunit while still retaining your operating functions to the ipod. Can be purchased for about 10 bucks on ebay.
May 21, 2009 | Alpine CDA-9887 CD Player
Stations on radio will not set
A car radio needs two sources of power. A little bit of 12 volt all the time and more power when you want to hear the music. Also known as battery(all the time) and ignition (when the "power" is on). It might be a bad connection on battery power or it wasn't connected right. Battery power is needed to keep the presets and the clock setting.
May 17, 2009 | Alpine CDA-9887 CD Player
Car Audio & Video Logo
61 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
