Question about Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range
Bertazzoni starter will not stop clicking
I'm having an immediate problem. Starter to start stove will not stop clicking even when I finally get a flame by using a barbecue lighter.  For some reason the flame will not come on.  Because of the constant clicking after I have the aforementioned flame by lighter, the clicking continues  I finally unplugged the stove.  I do need to cook dinner soon and would like someone to help me. I'm visiting. My daughter just had a baby and I'm the one cooking. Another complaint:   I love the heat of this stove but the flame will not go low. If I didn't move the pan (oatmeal, for example, the oatmeal would burn). Moving the pan to the side, cockeyed, keeps the oatmeal warm and creates a layer stuck to the pan. I frankly don't like this stove.  Help!!!!
Chernins where my son-in-law bought this stove is closed today, of all things!
  • 2 more comments
  • shigeno Jul 28, 2008
    You said "check your electrical contact."  I plugged the stove into the electrical outlet and right off the clicking started.  At least I pushed in the stove knob and then let go and the gas came on, with the clicking continuing.
    I turned the knob to off, clicking continues.  I saw the white piece with the light sparks.  What do you mean "check the electrical contact."  How do I check that white piece with small sparks?  Be elementary in your response.  I'm not familiar with this stove and I do not know anything about electricity.
    FixYa,
    Please have someone read my additional comment and respond.  I don't want to type up the comments (2) again.  Thanks.
  • shigeno Jul 29, 2008
    Please see my three earlier comments about one burner which won't stop clicking even with the burner in the off position. Now, it lights, but still clicks when off. The other three burners work fine.
    Well, after the second solution, the clicking continued to midnight. I unplugged the stove. This morning I plugged in the stove, started te burner causing the problem, clicking began immediately upon plugging in, then turned on the troublesome burner, released, the gas came on and flamed burned, clicking then stopped. So, it seems to have fortuitously stopped clicking on its own.
  • 640 Answers
Shigeno, its sounds like the ignition board going to that burner is acting up, another possibility could be the grounding wire to that burner is not grounded properly (dirty).
Posted on Jul 29, 2008
  • 818 Answers
Check your elettrical contact.
Sergio
Posted on Jul 28, 2008
Battery on 98 Ford Expedition
So why are you here !!
You have a bad starter solenoid or the starter
I have no idea why you would chance half a fix
& the possibility of breaking down back in July
You immediately stop using any vehicle the moment
any light stays on your dash after the motor is started,
anytime you have codes present,anytime you are aware
of a mechanical or electrical issues
You fix it right,immediately & completely, the proper way,
& be done with it
Feb 19, 2013 | 1998 Ford Expedition
GSF1250 Bandit - intermitant start. Starter motor will some times crank over and engine will start immediately. Other times the starter motor will not even click. Battery fully charged. Side stand up...
there is a common fault with the 1250 bandit in that the magnets detatch inside the starter motor and it eventually breaks up and stops working, this can begin with sluggish starter especially when hot, it would appear to be a flat battery but the power required by the failing starter can drop the battery off quickly to confuse you when trying to find your fault
Jun 12, 2011 | 2007 Suzuki GSF 1250 Bandit
How do I change the starter on a 99 avalon
Could be your starter, sounds like your starter soloinoid(pulls starter gear into flywheel) might be defective. First it will not pull gear in, then if it sticks in your car could keep starting even if the key was turned off .
without looking at the car I could'nt say how hard it would be to change. It has been my observation that newer cars are much more difficult to change
Jul 26, 2010 | 2000 Toyota Avalon
Electric starter won't stop clicking - how to unplug starter?
Your electric spark switches got wet. You may be able to remove the knobs and use a hair dryer through the switch/valve opening to dry them out.
Dec 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
Gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
Mar 01, 2009 | Stoves Kitchen Ranges
Starter won't disengage
You have a defective start, no 2 ways about it, and it may be hung up, which means there is no way that you will be able to start it or to disengage the starter. It will have to be towed, and as it is, the tow company can tow it.
jetski
Nov 27, 2008 | 1998 Toyota 4Runner
1999 Toyota Corolla CE. For about 2 months, the engine does not start immediately. I need to turn the ignition key several times until it starts. Each time when I turn the key, a clicking sound happens...
it sounds like either your having a short at the starter or the ignition switch is bad, I am leaning towards the issue being the starter, usually when the ignition switch is going bad there will be no click,
Oct 06, 2008 | Toyota Corolla Cars & Trucks
Gas Stove - Electric Starter
Just happened to me. I unplugged the electric starter, wiped up the water, took off burners, etc., and placed a fan over the stove. After about 3 hours, I plugged in starter and the clicking is no longer.
Sep 23, 2007 | Ovens
Stoves 1200DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
396 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
