Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have a whirlpool dryer and it is not turning, the motor is on, but it is not turning the clothes.
    Problem Solver:
  • 8 Answers
Funny thing, is that a belt turns the drum just like a fan belt turns on a car. maybe you could start there?
Posted on Aug 14, 2008
It was the belt and my husband fixed it.
Posted on Jul 29, 2008
Dryer won't spin
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Dec 05, 2012 | Whirlpool Dryers
My Whirlpool gas clothes dryer has no power.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2011 | Whirlpool Dryers
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Whirlpool Calypso dryer GEW9868KL2
    It is one or two things. Motor start switch or the motor itself.
    Aug 11, 2009 | Whirlpool GEW9868K Electric Dryer
    Whirlpool dryers element comes on and then turns off and does not dry cloths, help
    SOUNDS LIKE THE THERMAL DISC THAT CONTROLS THE TEMPERATURE OF THE DRUM IS BAD UNDER THE DRYER DRUM WHERE THE MOTOR IS LOCATED SHOULD BE TWO THERMAL DISCS ONE IS THE DRUM TEMP AND THE OTHER IS THE HIGH LIMIT OR HIGH TEMP SAFTEY TO STOP THE DRYER FROM OVER HEATING
    Aug 09, 2009 | Whirlpool WED6400S Electric Dryer
    Clothes dryer will not start
    sounds as if your motor has tightened-up or seized from heat and age bearing failure which it would cause excessive current draw at start-up if you can access the motor unplug unit then remove belt and spin motor pulley is should turn freely and coast to a stop if it seems tight the bearings are dried out
    Jul 12, 2009 | Whirlpool Dryers
    Dryer turns on - we hear the motor going - but the clothes do not tumble - the barrel isnt turning
    Hi welcome to Fixya
    You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
    The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
    PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
    Thank You For Useing Fixya
    PLEASE RATE ME
    May 17, 2009 | Whirlpool LEQ9858L Electric Dryer
    Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
    Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
    As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
    Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
    Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
    If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
    Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
    As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
    Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Thin twin stacked washer/dryer...dryer won't stay on
    My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
    Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
    Dryer Wont Spin
    most likely a motor, If machine runs but not turning, either belt broke, if direct drive, motor
    May 01, 2008 | Whirlpool LGV4634JQ Gas Dryer
    Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
