Question about Carrier Heating & Cooling
Carrier model# 38BRBO36300. Compessor tries to start but trips out. Already changed the capacitor.
  • 182 Answers
If it trips after trying to start....sounds like you need a compressor.Is this system metered by a txv?If so you may try a hard start kit.
Posted on Jul 29, 2008
Keeps triping on compessor overload
The start capacitor is going bad. Replace it before it ruins the motor in the compressor.
Oct 01, 2014 | Heating & Cooling
Failed capacitor on clarke SE 14 compessor
On electric motors with two capacitors, one is a start capacitor, the other is a run capacitor. Start capicitors have plastic cases and are rated from 200mf to 400mf and higher depending on the size of the motor. Run capacitors are in the 20mf to 40mf range and usually have metal cases. If you have an electric motor service center in the area they can recommend what size you should use for the size (HP) motor you have.
Oct 31, 2012 | Clarke Air Tools & Compressors
When the tank is empyt the compessor comes on with no problem and runs until it's full, once pressure gets low the compessor should automaticly come on and refill, that"s when the compessor comes...
Hi mcfadden21...
Check and clean or repair or replace your compressor's unloader valve.
The unloader valve is suppose to discharge the compressed air from the tops of the piston heads to the outside to make it easy for the compressor to start when the pressure in the tank drops to the starting point.
Please take time to rate me thumbs up
Sep 15, 2011 | Air Tools & Compressors
Air compessor wont start under load it is a airking 3 hp 3ph compessor and will not start under load.
was it running before? what ahpened to it? Is it on 3 phase service or a converter? Does it run with no air in it? Is there a trip for 2 or 3 circuits or just one? I would suspect th epower supply first, and then check the motor to see if it is ok. If it is a converter, they are only good for x amount or hours. Check it out.
Sep 07, 2010 | Ingersoll Air Tools & Compressors
I have a Carrier AC unit with a heat pump. I noticed that it wasn't cooling and the circuit breaker had tripped. When I reset the breaker and try to start it again, it trips againafter 10 seconds. The...
Check with your contractor to see if their repair is warrantied. If it is not call someone who carries a warranty and satisfaction guarantee on repairs. It is likely that you got a bad capacitor, however, this typically will not trip a breaker. It's possible that other issue(s) caused the capacitor failure.
How old is this unit?
Aug 26, 2010 | Carrier 38CKC060 Air Conditioner
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Compessor will start and fill tank initally .
Yes it would be a start cpacitor and yes you can still order the part from sears
Feb 16, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Heating & Cooling Logo
76 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
