Sanyo DVW-5000 DVD Player/VCR Logo
Posted on Jul 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
VCR to TV
We cannot record to the VCR from the TV when the TV is off--even though we have programmed the VCR to record. It will record when the TV is on--but not when it is off.
We are using FIOS, cable going from FIOS box to VCR, Cable from VCR to TV.
  • Anonymous Feb 21, 2009
    I have an HD cable box, Sony HDTV, Go Video combo dvd/vcr. Before getting the HDTV and HD box, the combo was attached to analog tv and digital cable box and I was able to recordwith the tv off.
    Now, I'm only able to record while the tv is on. I have rechecked the cables more times than I want to remember. Is something faulty with the cable box or is there a connection issue I'm missing?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
461
Points
I figured out my solution.
I had to disconnect my HDMI connection, and use the component setup for receiving the HD signal from the cable box. Upon using this connection, I am now able to record a channel even when the TV is off.
Tim Babcock
Level 3:
  • Master 2,794 Answers
  • Posted on Jul 28, 2008
Tim Babcock
Master
Level 3:
Answers
2794
Questions
13
Helped
1127933
Points
7249
Your FIOS box is typically a Motorola Digital Cable Tuner. In order to record from the VCR your FISO will have control of the tuner, not the vcr. If your FIOS has two video outputs on it for video (av connections), one should be plugged into you tv set and the other should be plugged into the VCR input. Your cable tuner will have to be set for the channel you wish to record ahead of time while the VCR tuner has to be set to record the line input at whatever time you wish to record. If your FISO has one video output line (av connections), your VCR has to be set to channel 3 when you record (provided that is the channel your FISO box is set for when viewing TV over the coax cable) and you will have to attach the coaxial output from the FISO into the coax input of your VCR.
The only way around this is to get a splitter and split the coax line so that the FIOS is connected to the coax as it is now and the VCR is connected to a seperate line using the coax input, however using this configuration will prevent you from recording digital channels. If you have a cable ready VCR, it will probably only recognize channels up to 150.
If you really want to get it to record digital channels without the hassles find out if Verizon has a FISO box with DVR to it or connect a Tivo to your FISO. Tivo will tune the FSIO when it records and it's very user friendly to use.
I am wondering how to record a tv show on a blank VCR tape. The VCR I have is a Memorex MVR2031 VHS VCR. Can you help with step by step directions?
Cable from Programming source to TV. Tv OUTPUT cables to VCR INPUT. You will need to check the VCR Manual if you still have it. retrevo.com doesn't have your model listed since it's classified as obsolete, even though many people still have VCR only units.
You have to set your recording channels on the TV to match the switches on the VCR. May have to do it by menus, remotes or both and or just switches on the back of your units.
Here are some basic how-tos:
http://www.ehow.com/how_5024699_setup-cable-tv-vcr.html
http://www.ehow.com/how_5126493_record-tv-shows-vcr.html
http://www.mvrhs.org/library/How_to/TV/VCR_Recording.html
http://www.ehow.com/how_6849_hook-vcr.html
Setup varies based on source of programming (ie satellite, cable, etc) Good luck. Hope this has helped.
How can I link my VCR to the HDTW in order to record programing?
A VCR cannot record HD programming. To record non-HD programs, you would need to hook the cable coming out of your cable box to your VCR, and then have a cable going from your VCR to your TV. If you hook it up this way though, there is a chance that you may have to have your VCR on in order to watch TV.
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Adding VCR to Samsung LN40B630NIF so I can record programs.
No.
You can not recording on any VCR from a digital TV.
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
2answers
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
Vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
How do I Record?
well, seems like your vcr is attached to your tv by the antenna cable which you need to program to get it to record. but he is an easy way to record and you will get a perfect sound and picture. Well, you need an RCA cables. you either have rca cables or scart plug. either on will do the job. you need to take the audio and picture cable OUT source of your channels IN to the vcr. now, OUT of the vcr IN to your tv. on the vcr you should change the channel to either AV or LINE..then you will get sound and picture. let me know how it goes
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
