Question about Panasonic Cameras
The camera turned off when I tried to zoom out. It kept happening. Now it just won't turn on. Charging the battery or trying to use it plugged in doesn't help.
Model PL81. Why does it zoom, beep, and shut down?
Are you positive that the battery is good? Turning on for a few seconds and then shutting down is a classic symptom of a battery that did not take a proper charge and as soon as the surface charge is used, unit will shut down. And what if your charger is not properly charging the battery?
If you have a battery eliminator try that in lieu of the battery to see what happens.
Mar 28, 2016 | Samsung Cameras
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Why won't my camera turn on or charge?
Battery may have died suddenly, as they can ! If charging from mains lead , check fuse , if charging from USB lead , check lead, connection. Re set camera , or take battery out, then re insert and try again to charge battery
Jun 08, 2015 | Panasonic HX-WA10 HD Camcorder - Blue 16MP...
S4500 Not Turning on
Is the battery fully charged? Try charging the battery for 24 hours and then try turning it on again.
Aug 25, 2012 | Fujifilm FinePix S4500 14MP, 30X Optical...
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
Camera won't switch on, put new batteries in it, took a photo to test, since then it won't switch on.
If you were able to take one shot before the camera packed up it can be that the battery does not have charge on it and so after the first shot it has drained the battery. So check out the charge on it or repeat charging to test once again.
Other wise it can be that the camera control unit is faulty. Try and reset by removing battery for a while and trying once again.
Jul 25, 2011 | Olympus Camedia D-540 Zoom Digital Camera
My Minolta Freedom Zoom will turn on and zoom but won't take pictures. The numbers dissapear when you try.
Hi. It could be that the camera needs more memory. Also replace your batteries. if the batteries are low the camera won't run properly.
Jun 26, 2011 | Cameras
I have a Fuji finepix j38. I went on the beach and it got a little wet and it wrote zoom error and now it isn't charging either.
Welcome to Fixya. Having a "zoom error" message is a camera malfunction, in this issue you can try to turn off and then turn it on again but this time you have to take care not to touch the camera lens or try not to blocked the camera lens while retrackting. If you still have the same issue you can try to visit this site for some steps you can do before sending your camera to your Fujifilm center.
In regards your issue about the charging of your battery,as you said before that you bought your camera to the beach. Try to clean the terminals with soft and dry cloth. Also, possible that the battery has reached the ends of its charging life. Purchase a new battery. If the battery still fails to charged, you have to contact your Fujifilm center.
Please let me know if you have any question.
Thank you for using Fixya.
Apr 27, 2011 | Fuji Cameras
My camera won't turn on. the screen flashes, but nothing happens. it turns right back off. the lens is pushed all the way out like its zoomed, but its obviously not since i cant so anything with it....
I would try a new set of batteries.. It sounds like maybe the batteries you are using are not charging correctly or that the cell has well... died.. so try a new set of batteries and if that doesn't fix the problem I would (if you have electronic experience) take out the screws and see if there are any loose components inside that are making it so the camera isn't operational
Jul 08, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Wont zoom
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Cameras Logo
13 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
