Question about HP Scanjet 4470c Flatbed Scanner
Scanning 35 mm slides
Scanning slides results in colored horizontal lines.  Descreening is not accessible when scanning slides.
Also ... when I scan a document and click on "Scan to" my computer freezes
  • 1 more comment
  • phxbrd Dec 27, 2008
    Same Problem Scanning slides then colored horizontal lines Help Thanks
  • Anonymous Jan 01, 2009
    I have the same problem but wit a Epson v300.
    Mostly a red line nearly half way up the frame but it can be blue or green.
  • curlywatts Jan 01, 2009
    I have the same problem but with an Epson perfection V300.
    Mostly a red horizontal line nearly half way up the frame but it can be blue or green.
    New Friend:
This is due to light leak, cover the scanner
Posted on Jul 06, 2015
  • 80 Answers
SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
Posted on Jul 29, 2008
SOURCE:
No picture. Just a thin horizontal band of light running through the center of TV.
HI,
Your tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). You can easily find out the vertical ic on your tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Mar 07, 2011 | Mitsubishi CK-35308 35" TV
I have sony triniton tv when i was turn on there is horizontal line on the center of screen this problem was never happen before
HI,
ur tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). u can easily find out the vertical ic on ur tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Jan 04, 2011 | Sony KV-35S42 35" TV
My Epson Perfection 4490 Scanner insists on scanning my 35 mm slides as regular color photos. How can I switch the dscanner to scan my slides as slides?
Of course that is what it will do. The same as ti will do as a negative. Neither can be printed out other than as a picture.
Sep 01, 2010 | Epson Perfection 4490 Office Flatbed...
How do i scan a photo with hp deskjet f340 all in one?
Place your document or picture on the glass. If scanning film, placethe 35 mm negative or slide in the special adapter provided by HP.Select the Scan Picture, Document or Film button depending on what youare scanning. Select the Make Copies button to copy the document orpicture directly. Click "Scan" and then "OK" to see the scan preview.
Jan 08, 2010 | HP Deskjet F340 All-In-One Printer
The 2400 Scanner quit scanning 35 mm slides as the top lid light
problem in the driver so pls check latested driver in the internet and download it then you problem will solved
Mar 17, 2009 | Epson Perfection 2400 Photo Flatbed...
SCANNING SLIDES ON TO PC
Hi svengoransso - it's not clear what your problem is! Yes, you can scan slides onto a PC using a variety of scanning methods. I use both a flat bed scanner with slide attachment, and a dedicated slide scanner. Do a google search for 35 mm slide scanner - you will get lots of info. If you have a more specific problem than this, please post a new comment explaining the problem as clearly as possible.
Mar 10, 2009 | Epson Stylus C86 InkJet Printer
After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Overall Blue Tint
You might try resetting the "settings" to factory defaults and then scanning again. I have seen strange tints if the settings get set incorrectly, not sure exactly what is wrong. However, using factory defaults corrects the problem, then change settings one at a time.
Jan 12, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
HP Scanjet 4470c Flatbed Scanner Logo
520 people viewed this question
Clive
Clive
Thomas F. Schneider
