Question about LG KU990 Viewty
Will Not Turn On !
I've had my little treasure for a long time now, basically, it sometimes turns off because of a loose battery connection, but that's solved by simply by taking out the battery putting it back in again and turning it on. I've done this countless times.
But today, when I decided to use my phone, I found it turned off. As I remembered it was low battery anyway, I put in the cable charger and it should've turned as it always does when putting in the charger. But it didn't. So I took out the battery put it back in and then turned it on.
Nothing. I tried taking the battery out over and over again. Nothing. My phone will simply not turn on, even with the cable charger plugged in.
I'm so frustrated and I cannot live without my mobile.
Please, please please !! Can anyone help me !??
  • rajkhan199 Aug 26, 2008
    Yup my Nokia 6133 was not used for about a year. Now I chenged the battery, tried to turn it on with charger plugged in, but it still will not turn on. It didn't have SIM inside, so I put a SIM but still not working
    Problem Solver:
  • 17 Answers
Your phone is water damged and has commonly soked in the test points. send this in as its a common manafacture fault as the new boards test points are covered and stops water damage.
Posted on Oct 04, 2008
2001 sub ura legacy will not start at times..all lights work when trying to start sometimes it trys to turn over other times there's a clicking noise when i turn the key
This is most likely a loose connection on the battery/the chassis earth or the starter motor, as sometimes its a good connection and other times not..
Mar 06, 2018 | Cars & Trucks
Hi I have a Polaris 500 magnum1999 I'm getting 15v dc at the battery when the Atv is running is that normal
That might be right, but seems a little high,, you run the risk of overcharging... usually about 13.5 - 13.8 is the max. Are you having any battery troubles? Please check the battery connections (wires/connections/terminals) for cleanliness and tightness. Use a file and wire brush to clean them. A bad/loose/corroded connection will cause excess resistance and thus excess voltage trying to overcome the bad connection. A little waterproof grease on the connections will keep away the corrosion.
Do the lights stay on all the time? If not, turn them on and check the voltage at about 3K rpm. If the lights are NOT on all the time, when you turn the lights on, you simultaneously turn on the night time charging circuit to boost the battery to offset the lights drain on the battery.
Check all these and then repost with the results.
May 29, 2017 | ATVs
2001 ford focus will not start
It sounds like...very frustrating. Really, a year?
If I understand correctly, sometimes the starter motor doesn't work? But every time the starter spins the engine, the car starts easily? If this is the case, then the problem is confined to the start circuit, which narrows it down a lot. Basically the starting circuit is the battery, the starter, and the ignition switch-and the wiring connecting and associated with the circuit.
It seems to be happening a lot now, so a tech with patience and understanding of your Focus starting circuit, should be able to have it occur and find the problem. It could be as simple as rust or corrosion on one of the electrical connections. The place to start is with the battery terminals and connections, the starter motor connections, battery ground connection and a couple of other grounds in the start circuit. The starter motor and attached starter solenoid could be taken off and tested on a machine to see if it has anything wrong. Parts stores will test them for free if people bring them in.
One thing you could try: you said slamming the hood might jolt something, and cause starting: sometimes you can cause a failing starter motor to turn on by tapping on the case. Find the starter- the positive battery cable is connected to it- and when it won't try to start, rap on the starter with a heavy screwdriver, or tap it sorta lightly with a hammer, then try to start. If it starts up, you have a failing starter. If it doesn't help, you will probably need someone with a multi-meter to check out the circuit.
Nov 16, 2013 | 2001 Ford Focus
My motorola defy keeps turning off
Have you checked that the battery is fitting in snugly, a lot of cellphones have that problem these days. Try to see if you can put something on the opposite side of the metal battery connection to get it to be more stable. Like little ball of paper or little piece of cardboard.
Another diagnosis is that your battery is bad. You can find a specialty battery store and ask them if they can test the battery for you, then you may need a new battery.
Sep 04, 2012 | Motorola Mobility Defy Cell Phone
Turn signals and brake lights not working properly...at one time neither worked at all and my battery was draining down. I can test for continuity between my positive battery post and the frame with...
I had a similar problem with a Ford Ranger. check the Main harness bulkhead connection at the firewall for looseness and corrosion. Then check the backside of the fuse block for loose connections at the affected fuse positions. The brake light switch needs to be adjusted at the pedal to affect brake light staying off when you take your foot off the pedal. This circuit is hot regardless of key switch position. Brake light switch adjustment done incorrectly can kill the battery.
Feb 28, 2017 | Cars & Trucks
1992 pontaic sunbird GT 3.1L V6 when I turn the ignition key to the position just before crank, everything seems normal for about 3 seconds, battery gauge shows full charge, gauges do their little...
SOUND LIKE DEAD BATTERY.HAVE BATTERY CHECKED AND REPLACED.MAKE SURE ALTERNATOR CHARGING BATTERY.WITH ENGINE IDLING BATTERY VOLTAGE OUTPUT AT BATTERY SHOULD BE 13.5 - 14.5 VOLTS. IF NOT CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE OR LOOSE CONNECTIONS,CHECK ALTERNATOR FUSE AND MAKE SURE ALTERNATOR DRIVE BELT NOT LOOSE SLIPPING OR BROKEN.
Jun 26, 2011 | Pontiac Sunbird Cars & Trucks
I have a 2006 Jeep Grand Cherokee Limited with the 4.7 engine. I have a problem with starting the car. Most times it will start fine and then out of the blue it won't start.All it does is click. If I try...
First thing to try is clean the battery cable connections, and make sure they are tight. Sometimes, if they are a little bit loose, or dirty, it won't make good enough connection to turn the starter. If that doesn't solve it, the connection to the starter, or ground to the engine may be loose or dirty, or your ignition switch may need to be replaced. Good luck. I hope this helps you.
Feb 20, 2011 | 2006 Jeep Grand Cherokee
My zen mp3 player won't turn on. It has been like this for two days. Yesterday I erase my files from the player and every since then, my usb plug won't respond to my computer.
The possible causes of the problem are:
1. Corrupted program.
2. Bad battery.
3. Loose wire connection.
If an mp3 device has a corrupted program, most of the time, it would turn on, but you cannot do anything. But there are times that the player will never turn on.
For defective battery or loose wire connection, the player will never turn on if it's disconnected from the computer. But it will turn on sometimes if it's connected.
For these possible causes, it's better to contact the manufacturer and have them check the player. Upgrading the firmware fix the problem for most of the time.
Thank you!
Feb 17, 2010 | Audio Players & Recorders
LG KU990 Viewty Logo
79 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
