You have to go into F-5 service mode to disable it.
While holding "function" key,press and hold "copy" key. While holding these two keys, press and hold "3" key. Press "5" then the green start key. Key in "42" then start key. Should show "KEY/DEPT counter". Press "no" to disable all codes. If you just want to disable printer codes while leaving copy codes intact, go to F5-65 to disable printer mode. After this, press "stop" key twice. While holding "function" key, press "clear" key to return to ready mode.
On the right side near the rear, there are ethernet and USB connections. You can get the drivers from Panasonic.net.
If you have a phone input on the back right near the bottom, you have a fax board installed.
