Question about PNY Technologies GeForce 6200 128MB AGP Graphic Card
How do I change the stat of "writeable only" on my optima attahche 2g?
I am now unable to save or copy anything to the opima attache 2g memory stick. How do I change this?
  • 781 Answers
Check another usb port I plugged my mouse in 1 port did not work plugged into another worked OK plugged thumb drive into port No 1 worked OK seems as if some usb port are funny
Posted on Jul 28, 2008
Hi am able to view my pictures on my camera, but am unable to copy them over to my system, i can see the pictures saved on the camera, but not on my memory card. please help
Follow the steps to move your pictures on your PC.
1- Turn on camera.
2- Press Menu.
3- Go to Memory Stick Tool
4- Copy and select OK.
5- All the pictures on the camera will be copied at memory stick.
6- Turn off the camera.
7- Insert your memory stick in any card reader.
8- Connect your card reader with your PC.
9- Copy all the data from memory card to PC.
And the job is done.
Hope this will help you.
Thanks.
May 14, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
How to put a photo in an email on to a memory stick
The photos must have come in as attachments or compressed in the mail. Click on it to save to a specified folder, maybe you document folder. Now connect the sandisk memory stick to the PC and right Click on the photo. Youget option to copy or to send it to the memory stick . copy the photo and open the memory card to paste the photos to the required folder inside.
Do these steps in the same order.
Aug 24, 2010 | SanDisk 4 GB Memory Stick PRO Duo Card...
I used Windows to format 4gb memory stick PRODuo, now what?
your 4gb drive has definately a partition virus.
i recommend u to use net protector a virus removal software to tackle this problem
may be demo version will not remove the virus but clean any malware and inform you about the virus.no other software may help as this 4 gb has a partition virus and there is an unseen partition (hidden one) on the drive... which the net protector will delete.
datarecoveryfactory
Sep 06, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Is there a way to transfer photos saved in internal memory to the memory card?
Try by removing the memory stick and then attaching the camera to computer with USB cable. Switch on camera. It should open up a dialogue box in Windows XP (or similar OS). Select 'open folder to view file' or open Windows Explorer and open camera folder (probably displayed as new drive E: or like that in My Computer) . You may also check whether there is an option of selecting "camera as mass storage device" in settings menu of camera. If yes then select this before connecting. If you have no means of attaching the camera to the computer, place an empty memory stick into the camera. In review mode, a message indicates there is no data, but there is in the internal memory. While still in review mode, press the menu button and go the the "Setup" section, the last option. Now, scroll down to the "Memory Stick Tool" section. From there, highlight the "Copy" choice at the bottom, and select the OK option to proceed. You will get a message: "All data in internal memory will be copied." Press OK, and it will copy everything in the internal memory to your memory stick. Then, when you have plugged the memory stick into your computer, you will find a new folder entitled Copy. All your photos from the internal memory of the camera will be in there.
Thanks.
Aug 07, 2009 | Fuji FinePix Z10fd Digital Camera
Unable to save in the memory stick
the memory card automatically locks wen u insert in the phone...
go to moto service centre
Jul 07, 2009 | Motorola Mobility ROKR E6 Smartphone
I need to know the steps to save data onto usb memory stick from accounting program
I suggest that you save your data with Simply Accounting and know where you save it. In window explorer, find the file you saved and copy it to the USB memory stick. You should see the USB memory stick as another drive in Windows Explorer. After the copy is complete, Click the USB memory stick and you should see the file. This way, the copy (back up) is confirmed.
May 30, 2009 | Dell Computers & Internet
2g attache optima pro went to write protected...
You can see the following link
http://www.fixya.com/support/t275843-pny_optima_attache_4g
I'm not sure , if this would work for you, but you can definitely give it a shot . Fixing flash drive problems , the chances are 50-50.
Best of luck
Proton
Apr 05, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro black/amber went to write protected...how do I fix it?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Memory
The best way around this problem is to have a card reader installed on your PC.
Using the card reader you can format, delete, copy or whatever just like it was a hard drive attached to the computer.
You can even get a usb card reader so there is no need to install anything into your PC. Check yourlocal PC for either version.
There is however a possibility that the card has been put into write protect mode. Pull the card out and there will normally be a tiny switch. One way is writeable, the other is write protected.
Let me know how you go =)
Apr 11, 2008 | Casio Exilim EX-S600 Digital Camera
Computers & Internet Logo
56 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
