Question about Sanyo MM-5600
How to reset the sanyo mm 9000 cell phone back to orginal
I forgot security code and how to reset it back
with the nokia phone to reset the code go to menu-settings-and in there will be a button that says reset to orginal, the factory security code is ether 0000 or 5555 mine was 5555
Sep 21, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
My computer is asking for a software or driver for my sanyo 7400 phone i dont have one
for software and driver go to the sanyo website in support section you will find the software and driver for your sanyo 7400
Mar 17, 2010 | Sanyo MM-7400
Lost driver disk
You may click this link:
http://www.accessorygeeks.com/cell-phone-data-cable-usb-datacables.html
After clicking this link, locate the brand "Sanyo" and click the icon on the right. You will get another screen and then hit "Save file". That is the driver for your Sanyo MM-9000
Apr 25, 2009 | Lands Phones
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
Sanyo 7400
The charging circuit has failed; time for a new phone.
I love my BBW MM-7400, had mine for years…
Great phone; never a problem with her.
Mar 26, 2008 | Sanyo MM-7400
To unlock code no. of sanyo mm-8300
call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Mar 14, 2008 | Sanyo MM-8300
Changing language on sanyo MM 8300
hi there
you can change back to default english by pressing shortcut keys.
press menu/ok
select settings
press options(right softkey)
then select language
now slect english.
hope this helps.
Feb 07, 2008 | Sanyo MM-8300
Sanyo mm-8300
Call Sprint tech support at 1-888-211-4727 see if they can help.
Nov 30, 2007 | Sanyo SCP-3100 Cellular Phone
Unlocking a Sanyo 7400
try this type the code ##726400# on the home screen it will come up with some options
view
edit
done
click edit and type ur number in
027.......
then
173.......
with the second thing (173.......) do not put 027 in it went ur done that it will tke u back 2 the main menu and click done and it will resstart ur phone u will still have every thing but ur code will be the last 4numbers of ur phne number and that will sovle ur problem hope it helps
Oct 18, 2007 | Sanyo MM-7400
Cell phone disassembly
The screw is hidden underneath the plastic so you'd have to break the plastic to take apart the flipper. Not sure how you would put it back together though.
Oct 18, 2006 | Sanyo MM-7400
Sanyo MM-5600 Logo
70 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
