Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE side-by-side My new refrigerator holds 0 & 36 degrees most of the time. I have noticed that the freezer will indicate -9 for a short period of time every couple days. Is this a normal cycle? I've been unable to find anything about this in the owner's manual. -thanks
  • 958 Answers
It is getting too cold if that is your inquiry. i guessed they could even go down up to -10 F. i think it is normal unless the freezer would build up ice then the temp would shoot up.
cheers,
drcool
Posted on Jul 29, 2008
Model ZFSB26DNA SS Side by side / refrigerator and freezoe not able to get cool enough. Refrigerator side temp 49 freezer temp 7
refrigerators run from 5 to 10 degrees C so your machine is on the upper limit of 9 degrees c
the freezer is at minus 13 degrees c and most work down to minus 20 degrees c so that is in limits
Get a technician in to check the thermostats and in the mean time check the condition of the door seals as they will loose the cold very easily is cracked or not sealing properly
Nov 04, 2015 | GE Refrigerators
GE TFX22P Refrigerator Evaporator Fan
Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
if temp ok, do not wory about it.
Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
What is the ideal temp setting in GE side by side refrigirator. I have Freezer (0-9) Refrigirator (0-9) There was ice on the Freezer wall and the service guy replaced the defrost thermostat recently
If replacing the defrost thermostat fixed the icing problem that doesn't indicate your settings are wrong. But the desired temp in the freezer is from 0 to 10 degrees and in the fridge around 35 degrees.The actual number on your dial depends on the personal use. Use a thermometer to check it and allow 24 hours after changing it to check it.
May 25, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Freezer side cold fresh side not GE GSH22KGMD
Find the return air It can't come in if it can't get out. also if you were checking it with the freezer door open you will not feel the air. Just in case i have done that myself. if all air ducts are open and it's getting o I should be 20 in fresh food with the control on 9.
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer and fresh food sides not staying cool.
If you truely have a leak in the system that would need to be properly taken care of if you ever want to return to normal operation. If the defrost timer goes bad usually you will completely freeze up the coils which causes air circulation problems and only the very lowest part of the freezer (and sometimes fridge) sections will freeze. The upper top of the unit won't be very cold. Same thing happens if the evap. fan (above the coils) goes out (no air circ.).
Jan 15, 2007 | GE GSS22JEM Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
