Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Compaq presario 5423us and both memory modules were the same.512mb ddr pc2100 266mhz 184-pin.
Your computer will accept a maximum of 1 GB of memory. When you turn the computer on, after installing the full 1GB, do you hear any additional beeps? One beep means that everything checks out good. More than one beep means there was a hardware related issue. If you hear more than one beep, tell me how many you hear, and if they are long or short beeps.
I will also need to know the bios manufacturer and version number. You can find this information by entering setup, it will be listed at the top of the first setup screen. Press either F2, F10, or DEL keys during boot. It should say at the bottom of the screen which key to press.
However, if you hear only one beep, revert back to a memory configuration that allows the monitor to work, then go into the display settings window, click on settings, then advanced, monitor tab, and change the refresh rate, first to a lower refresh rate then to a higher refresh rate. You will need to reinstall 1 GB of memory each time you change the refresh rate. continue adjusting the refresh rate until you've either exhausted all possibilities or your monitor works with 1 GB installed.
Let me know what happens.
What is the make and model of your computer?
I will need this to find out the maximum memory capacity of your computer.
Also, when you installed both 512 MB memory modules were they the same brand and part number for each stick?
